- #36
gary350
- 271
- 61
Vanadium 50 said:You were the one who claimed that some compasses measure different magnetic fields than others. Apart from going against several centuries experience with magnetism, it is contrary to all good sense and logic. So it seems to me the burden is on you to prove your iconoclastic and heterodoxical beliefs, not mine. (However, before you go down that path, I recommend you review the PF Rules on personal theories. Wouldn't want to have it removed as crackpottery, would we?)
A compass is a device to measure the direction of the local magnetic field. The local magnetic field has one value, with one direction. It does not have multiple values depending on the imputed presence or absence of various nearby objects. That would be like having two thermometers, one that tells you the temperature of the room with the air conditioning on and another with the air conditioning off. Instead, a thermometer measures the actual temperature in the actual room, and not the imagined temperature in some speculative room. A compass does the same thing - it measures the real magnetic field, and not some imaginary field for some counterfactual arrangement of nearby objects.
I am not claiming a compass can measure a magnetic field. A claim a cheap toy compass does not have a good strong pointer needle magnet like a much better quality more expensive compass. Directions that come with a compass says, keep it away from metal objects to get an accurate reading. Sometimes wind moves my TV antenna then I have to reset it. I have noticed the toy compass works best to aim the TV antenna in the correct direction because the toy compass is not attracted to the metal antenna tower from 5 ft away. I have to walk 20 ft away from the antenna using the good quality compass. The good quality compass is effected by all the metal objected in the yard, patio furniture, cars in the driveway, garden tools leaning up against the tree, tiller in the garden, lawn mower in the shed, chain link fence around the yard. I have noticed the good quality compass can be used to find nails in the sheet rock wall once I find a nail I know there are other studs in the wall all 16" apart this helps me hang pictures on the wall for my wife. The toy compass is a pain in the butt trying to find nails in the wall but when either of the compass get close to a nail the needle points right at the metal nail.
Do this experiment. Buy a stack of magnets here. https://www.ebay.com/itm/Super-Strong-N35-Round-Disc-Neodymium-Mini-Fridge-Magnets-Rare-Earth-New/173384504513?var=&hash=item285e8594c1 put the stack on a float in a plastic tray of water in the yard away form all metal. The float boat will rotate to North south direction. Now move a piece of metal near the plastic tray the float boat will move toward the metal. Compass needle does the same thing.
