How to find Vmax squared for circular motion?
In summary: So, when we fall for 1 second, our velocity increases by 9.81 m/s. After 2 seconds, our velocity will be 2 x 9.81 = 19.62 m/s. After 3 seconds, our velocity will be 3 x 9.81 = 29.43 m/s, and so on.The force of gravity pushing on an object is the mass of the object, multiplied by the acceleration of gravity (9.81 m/s²).In summary, the equation T= m*vmax^2/r represents the maximum tension Tarzan can tolerate while swinging on a vine, with a mass of 80 kg and a vine length of 4.5 m. Considering Tarzan
Jade_lowe
Tarzan plans to cross a gorge by swinging in an arc from a hanging vine. if his arms are capable of exerting a force of 1500 N on the vine, what is the maximum speed he can tolerate at the lowest point of his swing? His mass is 80 kg, and the vine is 4.5 m long.
Fmax= mvmax^2/r
T= m*vmax^2/r 1500 = (80kg)vmax^2/4.5
Jade_lowe said:
Homework Statement:: Tarzan plans to cross a gorge by swinging in an arc from a hanging vine. if his arms are capable of exerting a force of 1500 N on the vine, what is the maximum speed he can tolerate at the lowest point of his swing? His mass is 80 kg, and the vine is 4.5 m long.
Relevant Equations:: Fmax= mvmax^2/r
You forgot to consider Tarzans weight.
The mass is his weight.
No. It isn’t. Do a free body diagram of Tarzan at the base of the swing.
This is what the question gave me.
We’ll, they should have stated local ##g## too, but you can assume 9.81 m/s².
Think about Tarzan just hanging there with zero velocity. Does your equation make sense for ##v=0## in terms of the tension developed in his arms?
Welcome, @Jade_lowe !
Our weight is a force (measured in Newtons) with which gravity pulls the mass (measured in kilograms) of our bodies down.
In free fall, our bodies are accelerated (the falling velocity increases) at a rate of 9.81 meters per second, for each second that goes by.
