How to find water vapor volume at different pressures than atm?
In summary: Then at 10 psi, you multiply that kg by the specific volume at that temperature.In summary, when a known amount of 300 liters of water gas is transferred from an atmospheric chamber to a chamber with reduced pressure of 10 psi, the volume and/or moles change. The accurate calculation for this change can be done using the ideal gas law or by using a steam table with the specific volume at various temperatures and pressures.
rhinohugger
If a known amount, let's say 300 liters of water gas (water vapor) is flowing from an atmospheric (14.7 psi) source/chamber, into a chamber of reduced pressure of 10 psi, does the volume amount and/or moles change?
So I believe I would multiply the 300 liters by the pressure ratio, but not sure which pressure value is the denominator, which is the numerator
I believe its either: 300 L * (10psi / 14.7 psi) which is 204.1 liters,
or it is: 300 L * (14.7 psi / 10 psi) which is 441 liters
Thanks for any help, I am leaning more towards 441 liters as my answer
Hi rhinohugger. Welcome to Physics Forums.
If the new chamber were initially empty (vacuum) and you could get all the moles into the new chamber at 10 psi, and, if the temperature were held fixed, then using the ideal gas law the way you did would give you a pretty accurate answer. If you needed a more accurate answer, you would have to use a more accurate equation of state, or you could use the steam tables (which have the specific volumes at various temperatures and pressures tabulated for you).
Chet
Thanks for the quick reply Chet,
1.So to clarify, the ideal gas method of 300 L * (14.7 psi / 10 psi) [NOT 10 psi /14 psi], would provide an accurate answer?
2. Also, I am looking at a steam table currently on engineering toolbox.
To use one to find a more accurate answer, I would look at the pressure on the steam chart (10 psi, in my case) and look find the specific volume which is in m^3/kg, so I would have to first calculate how many kg are in 300 liters of water vapor at 14.7 psi, and multiply it by the specific volume?
Yes, as long as it is at the same temperature.
No. At 14.7, you take the specific volume at the particular temperature (≥100C) and divide it into 300 liters (0.3 m^3) to get the kg.
.Your approach is correct. To find the volume of water vapor at a different pressure than atmospheric, you would use the ideal gas law: PV = nRT, where P is the pressure, V is the volume, n is the number of moles, R is the gas constant, and T is the temperature. In this case, we are assuming that the temperature remains constant.
To find the volume at a different pressure, we can rearrange the equation to solve for V: V = (nRT)/P. In this case, we know the initial volume (300 liters) and pressure (14.7 psi), so we can plug those values in and solve for n. This gives us n = (300 L * 14.7 psi)/(0.0821 L*atm/mol*K * 298 K) = 12.66 moles.
Now, to find the volume at a different pressure (10 psi), we can plug in the new pressure and the number of moles we just calculated: V = (12.66 mol * 0.0821 L*atm/mol*K * 298 K)/10 psi = 309.9 liters.
So, the volume does change when the pressure changes. Your second calculation (441 liters) is incorrect because you used the wrong pressure in the denominator. It should be 10 psi, not 14.7 psi.
Related to How to find water vapor volume at different pressures than atm?
1. How is water vapor volume affected by changes in pressure?
As pressure decreases, the volume of water vapor increases and vice versa. This is due to the fact that changes in pressure affect the vapor pressure of water, which is the pressure that water exerts when it is in its gaseous state.
2. Can the volume of water vapor be calculated at different pressures?
Yes, the volume of water vapor can be calculated at different pressures using the ideal gas law, which states that the volume of a gas is directly proportional to its temperature and inversely proportional to its pressure.
3. What are the units of measurement for water vapor volume?
Water vapor volume can be measured in various units such as liters (L), cubic meters (m3), and cubic feet (ft3). It is important to use the appropriate units in calculations to ensure accurate results.
4. How does temperature affect water vapor volume at different pressures?
Temperature plays a crucial role in determining the volume of water vapor at different pressures. As temperature increases, the volume of water vapor also increases, and as temperature decreases, the volume of water vapor decreases.
5. Are there any other factors that can affect the volume of water vapor at different pressures?
Yes, besides pressure and temperature, the amount of water vapor present and the type of container in which the water vapor is contained can also affect its volume at different pressures. In addition, external factors such as humidity and air flow can also impact the volume of water vapor.
