How to find z^n of a complex number
In summary: There is a very very similar problem to this one; where z is ##z = \frac{6}{1+i} ## The exact same is required and I did everything the same. I got z = a+bi and polar form; both are correct according to the solutions.And I tried the same formula I used here and I get the same result ##z^4 = -324 ## and this is the correct result.What am I missing in the first example? Is it just luck that in the second example the solutions match, and I am not doing this right? If this is not the way how should I approach this.Thanks in advance!No expert here, but
arhzz
268
52
Find z^6 of a complex number
Hello! (Not sure if this is pre or post calc,if I am in the wrong forum feel free to move it)
So im given this complex number ## z = \frac{6}{1-i} ## and I am susposed to get it in polar form as well as z = a+bi
I did that; z = 3+3i and polar form ##z =\sqrt{18} *e^{\pi/4 i} ##
Now Im susposed to find ##z^4 ## I didnt know how to that of the top of my head so I googled a bit and found that this should work.
$$ z^n = r^n(\cos(\phi n) +i\sin(\phi n)) $$ Okay so my n = 4, phi should be 45 degrees. So i typed everything in my calculator and I get -324.
This is wrong,the answer should be ##z^4 = -243 ## But here is the part that confuses me
What am I missing in the first example? Is it just luck that in the second example the solutions match,and I am not doing this right? If this is not the way how should I approach this.Thanks in advance!
No expert here, but I get z= 3 +3i and z^4 = -324 same as you.
For the second, z= 6/(1 +i) I get z=3 -3i and z^4 = +324
Maybe the first -243 is a typo?
Hmm I dont know I'm really starting to suspect it might be a typo.But how do you get a positive value for the second one? Could you please post how you are calculating that?
arhzz said:
Homework Statement:: Find z^6 of a complex number
Relevant Equations:: -
I did that; z = 3+3i and polar form ##z =\sqrt{18} *e^{pi/4 i} ##
Now I'm supposed to find ##z^4 ## I didn't know how to that of the top of my head so I googled a bit and found that this should work.
You could write z as ##\displaystyle z =3\sqrt{2}\ e^{(\pi/4) i} ## . Right? (Use \pi for ##\pi##.)
What is ##\displaystyle \left(3\sqrt{2} \ e^{(\pi/4) i}\right)^4 ## ?
$$ z^n = r^n(cos(\phi n) +isin{\phi n) $$ Okay so my n = 4, phi should be 45 degrees. So I typed everything in my calculator and I get -324.
This is wrong. The answer should be ##z^4 = -243 ## But here is the part that confuses me
Yes I agree, as does my calculator which does complex math. The answer is -324 for both.
I guess the real lesson here is to recheck your work and then be confident. Can you bill your instructor for your lost time?
Likes arhzz
To be honest I did not lose so much time on that. I've also checked my work multiple times and did another similar problem and it gives me the correct result (calculating it the same way I did the first 2 problems)
Thanks for your help!
Likes DaveE
Oops, yes. -324 for both. Sorry. (-18i)^2 = (+18i)^2 = -324
Likes arhzz
Thanks in advance!
I didn't read the second part of your OP carefully enough.
Also, I assume that the Homework Statement should be: Find ##z^4## of a complex number.
So you first had ##\displaystyle z = \dfrac{6}{1-i}##, which can be written as ##\displaystyle z=3+3i##. You also found that in this case, ##\displaystyle z^4 = -324 ## , which is correct, as several people have said.
Then you mentioned another problem, namely, find ##z^4## for ##z## being ##\displaystyle \dfrac{6}{1+i}## . (For this ##z## you should find ##\displaystyle z=3-3i##). You seemed puzzled to find that even though ##z## was different, you got the same value,
##-324,## for ##z^4##.
To help answer why they're the same:
What do you get for ##\displaystyle (3+3i)^2## ?
What do you get for ##\displaystyle (3-3i)^2## ?
Likes arhzz
Alternatively:$$(1-i)^4 = 1 -4i -6 +4i +1 = -4$$$$(1 + i)^4 = 1 +4i -6 -4i +1 =-4$$
Likes arhzz and SammyS
Got it now thank you!
[itex]1 + i[/itex] and [itex]1 - i = \overline{1 + i}[/itex] are complex conjugates. Since [itex]\overline{z^n} = \bar{z}^n[/itex] for any positive or negative integer [itex]n[/itex], [tex]\left(\frac{6}{1 + i}\right)^{4} = \left(\frac{6}{\overline{1-i}}\right)^{4} =
\overline{\left(\frac{6}{1 - i}\right)^{4}} = \overline{-324} = -324.[/tex]
Likes DaveE, arhzz, DrClaude and 1 other person
Fixed the issue with ##\pi## in the OP, and edited a subsequent equation that wasn't rendering.
I find it much quicker to write ## than [itex] for inline Tex, and $$ rather than [tex] for standalone Tex.
FAQ: How to find z^n of a complex number
How do you find the power of a complex number using De Moivre's Theorem?
To find \( z^n \) of a complex number using De Moivre's Theorem, first express the complex number \( z \) in polar form as \( z = r(\cos \theta + i \sin \theta) \). Then, De Moivre's Theorem states that \( z^n = r^n (\cos(n\theta) + i \sin(n\theta)) \).
What is the polar form of a complex number?
The polar form of a complex number \( z = a + bi \) is \( z = r(\cos \theta + i \sin \theta) \), where \( r = \sqrt{a^2 + b^2} \) is the magnitude of \( z \) and \( \theta = \tan^{-1}(b/a) \) is the argument of \( z \).
How do you convert a complex number from rectangular form to polar form?
To convert a complex number \( z = a + bi \) from rectangular form to polar form, calculate the magnitude \( r = \sqrt{a^2 + b^2} \) and the argument \( \theta = \tan^{-1}(b/a) \). Then, express \( z \) as \( r(\cos \theta + i \sin \theta) \).
Can you find the power of a complex number without using De Moivre's Theorem?
Yes, you can find the power of a complex number without using De Moivre's Theorem by multiplying the complex number by itself \( n \) times. However, this method is less efficient and more error-prone compared to using De Moivre's Theorem.
What is an example of finding the power of a complex number using De Moivre's Theorem?
Consider the complex number \( z = 1 + i \). First, convert it to polar form: \( r = \sqrt{1^2 + 1^2} = \sqrt{2} \) and \( \theta = \tan^{-1}(1/1) = \pi/4 \). Using De Moivre's Theorem to find \( z^3 \), we get \( (\sqrt{2})^3 (\cos(3 \cdot \pi/4) + i \sin(3 \cdot \pi/4)) = 2\sqrt{2} (\cos(3\pi/4) + i \sin(3\pi/4)) \).
