How to Fourier-transform e^(-2|t|)?
In summary, to Fourier-transform e^(-2|t|), you would first take the absolute value of t and multiply it by -2. Then, you would take the exponential of that result. After that, you would perform the Fourier transformation by integrating the function multiplied by the complex exponential e^(-iwt) from negative infinity to positive infinity. The resulting Fourier-transformed function would have a peak at the frequency w=2 and would decrease exponentially as the frequency increases.
TheSodesa
224
Determine the Fourier-transfroms of the functions
\begin{equation*}
a) f : f(t) = H(t+3) - H(t-3) \text{ and } g : g(t) = \cos(5t) f(t)
\end{equation*}
and
\begin{equation*}
b) f : f(t) = e^{-2|t|} \text{ and } g : g(t) = \cos(3t) f(t)
\end{equation*}
The Fourier transformation definition:
\begin{equation}
\digamma\{ f(t) \}(\omega) = F(\omega) = \int_{-\infty}^{\infty} f(u)e^{-j\omega u}\,du
\end{equation}
What to do with cosines:
\begin{equation}
\digamma\{f(t)\cos(\alpha t)\}(\omega) = \frac{1}{2} F(\omega - \alpha) + \frac{1}{2}F(\omega + \alpha)
\end{equation}
I managed part a) somewhat:
\begin{align*}
\digamma\{ f(t) \}(\omega) &= \int_{-\infty}^{\infty} \left( H(t+3) - H(t-3) \right) e^{-j\omega u} \,du \\
&= \int_{-3}^{3} e^{-j\omega u} \,du = \left[ \frac{e^{-j\omega u}}{-j\omega}\right]_{-3}^{3}
= \left( \frac{e^{-j3\omega }}{-j\omega} - \frac{e^{j3\omega}}{-j\omega} \right)\\
&= \left( \frac{ e^{j3\omega}}{j\omega} - \frac{e^{-j3\omega }}{j\omega} \right) = \frac{1}{2j\omega}(e^{j3\omega } - e^{-j3\omega })\\
&= \frac{\sin(3\omega)}{\omega} = 3 sinc(3\omega)
\end{align*}
Sinc is continuous at ##\omega = 0##, so we don't need to handle that case separately.
Then, using equation (2) I wrote
\begin{align*}
\digamma\{ f(t) \cos(5t) \}(\omega) &= \frac{3}{2} sinc(3(\omega-5)) + \frac{3}{2} sinc(3(\omega+5))
\end{align*}
Part b) has me completely stumped. Since
\begin{equation}
|u|=
\begin{cases}
u &, u\geq 0\\
-u &, u < 0,
\end{cases}
\end{equation}
we write, according to equation (1):
\begin{align*}
\digamma\{ f(t) \}(\omega) &= \int_{-\infty}^{\infty} e^{-2|u|} e^{-j\omega u} \,du = \int_{-\infty}^{\infty} e^{-2|u|-j\omega u} e^{} \,du\\
&= \int_{-\infty}^{0} e^{2u-j\omega u} \,du + \int_{0}^{\infty} e^{-2u-j\omega u} \,du\\
&= \lim_{a \to \infty} \int_{-a}^{0} e^{(2-j\omega) u} \,du + \int_{0}^{a} e^{-(2+j\omega) u} \,du\\
&= \lim_{a \to \infty} \sij{-a}{0} \frac{e^{(2-j\omega) u}}{(2-j\omega)} + \sij{0}{a} \frac{e^{-(2+j\omega)u}}{-(2+j\omega)}\\
&= \lim_{a \to \infty} \left( \frac{e^0}{(2-j\omega)} - \frac{e^{-a(2-j\omega)}}{(2-j\omega)} \right)
+ \left( \frac{e^{-a(2-j\omega) }}{-(2+j\omega)} - \frac{e^0}{-(2+j\omega)} \right)\\
&= \lim_{a \to \infty} \left( \frac{1}{(2-j\omega)} - \frac{e^{-a(2-j\omega)}}{(2-j\omega)} \right)
+ \left( \frac{e^{-a(2-j\omega) }}{-(2+j\omega)} + \frac{1}{(2+j\omega)} \right) \\
&= \lim_{a \to \infty} \frac{1}{(2-j\omega)} + \frac{1}{(2+j\omega)} - \frac{e^{-a(2-j\omega) }}{(2+j\omega)} - \frac{e^{-a(2-j\omega)}}{(2-j\omega)}\\
&= \lim_{a \to \infty} \frac{(2+j\omega)}{(2+j\omega)(2-j\omega)} + \frac{(2-j\omega)}{(2+j\omega)(2-j\omega)}\\
&- \frac{(2-j\omega)e^{-a(2-j\omega) }}{(2+j\omega)(2-j\omega)} - \frac{(2+j\omega)e^{-a(2-j\omega)}}{(2+j\omega)(2-j\omega)}\\
\end{align*}
This isn't looking good. Is there a trick that I'm missing? Help would be appreciated.
\begin{equation*}
\end{equation*}
and
\begin{equation*}
\end{equation*}
\begin{equation}
\end{equation}
If you write ##\cos(3t)## in terms of ##e^{\pm 3 j t}## you have
$$\int_{-\infty}^0 e^{-j w t} e^{\pm 3 j t} e^{2t} \, dt = \frac{1}{2 - j w \pm 3 j} \left. e^{-j w t} e^{\pm 3 j t} e^{2t}\right|_{-\infty}^0,$$
which is convergent because of the exponential damping factor ##e^{2t}## when ##t \to -\infty##. Similarly for the other part.
In the ##\left[\frac{etc.}{etc.}\right]_0^a## term you omitted the u from the exponent, but that's just a typo. What I do not get is what happened to that term in the next line. How did (2+jω) turn into (2-jω)? Maybe just another typo, rectified later, but this is making it hard to follow.
Likes TheSodesa
haruspex said:
In the ##\left[\frac{etc.}{etc.}\right]_0^a## term you omitted the unfrom the exponent, but that's just a typo. What I do not get is what happened to that term in the next line. How did (2+jω) turn into (2-jω)? Maybe just another typo, rectified later, but this is making it hard to follow.
Yhea, I just noticed. Fixing.
Ok, so right now I have
\begin{align*}
\digamma\{f(t)\}(\omega) = \lim_{a \to \infty} \frac{(2+j\omega)e^{a(2-j\omega) }}{(2+j\omega)(2-j\omega)}
+ \frac{(2-j\omega)e^{-a(2-j\omega)}}{(2+j\omega)(2-j\omega)}
\end{align*}
Not compeltely sure what to do here. I'm trying to edit my offline LaTeX document at the same time, so mistakes are bound to be made.
\begin{align*}
\end{align*}
You still have 2-jω in both exponents.
Likes TheSodesa
\begin{align*}
\digamma\{f(t)\}(\omega) &= \lim_{a \to \infty} \frac{(2+j\omega)e^{a(2-j\omega) }}{(2+j\omega)(2-j\omega)}
+ \frac{(2-j\omega)e^{-a(2+j\omega)}}{(2+j\omega)(2-j\omega)}\\
&= \lim_{a \to \infty} \frac{(2+j\omega)e^{a(2-j\omega) } + (2-j\omega)e^{-a(2+j\omega)}}{(2+j\omega)(2-j\omega)}
\end{align*}
There. I think it might have been a bad idea to try and learn LaTeX proper by doing all of my coursework with it. Copy-paste can be treacherous.
It looks like I have a sum of complex conjugates in the numerator.
It's not the cosine, that scares me. What I'm ahving trouble with is ##f(t)##. I also made a few mistakes in the opening post because I'm copyin stuff from my offline LaTeX-document. They should be fixed now.
No, there's still a problem.
Look at the last two lines of your original post. In the left hand integral, you had -a in the exponent, but it becomes +a.
As Ray says, it should converge.
I would not have introduced the lim operators, though I know that is technically correct. I would have just integrated still with infinities in the bounds, and used the fact that ex+iy tends to zero as x tends to minus infinity regardless of what y does.
Alright, let me go over it once more. This might take a moment.
I got it. Just a sec, and I'll clean up my derivation.
Your ##f(t) = e^{-2|t|}## is no problem; that is why you used ##e^{2t}## for ##t < 0## and ##e^{-2t}## for ##t >0##. You get two convergent integrals. It is even faster and easier to use standard expressions for ##\int e^{at} \cos(bt) \, dt##, then use ##b = 3## and
$$ a = \begin{cases} -j\omega + 2, & t < 0\\
-j \omega - 2,& t > 0
\end{cases}
Likes TheSodesa
Alright, here's the complete derivation this time (hopefully) without errors:
\begin{align*}
\digamma\{ f(t) \}(\omega) &= \int_{-\infty}^{\infty} e^{-2|u|} e^{-j\omega u} \,du = \int_{-\infty}^{\infty} e^{-2|u|-j\omega u} \,du\\
&= \lim_{a \to \infty} \left[ \frac{e^{(2-j\omega) u}}{(2-j\omega)}\right]_{-a}^{0} + \left[ \frac{e^{-(2+j\omega)u}}{-(2+j\omega)}\right]_{0}^{a}\\
+ \left( \frac{e^{-a(2-j\omega) }}{-(2+j\omega)} + \frac{1}{(2+j\omega)} \right)\\
&= \lim_{a \to \infty} \frac{1}{(2-j\omega)} + \frac{1}{(2+j\omega)} - \frac{e^{-a(2-j\omega) }}{(2+j\omega)} - \frac{e^{-a(2-j\omega)}{(2-j\omega)}\\
&- \frac{(2-j\omega) \overbrace{e^{-a(2-j\omega) }}^{\text{Real coefficient goes to zero...}}}{(2+j\omega)(2-j\omega)}
- \frac{(2+j\omega)\overbrace{e^{-a(2-j\omega) }^{\text{... specifically exp(-2a)}}}{(2+j\omega)(2-j\omega)}\\
&= \frac{(2-j\omega) + (2+j\omega)}{(2+j\omega)(2-j\omega)} = \frac{4}{4 + \omega^2}
\end{align*}
Then, if we apply equation ##(2)## to the case where we multiply ##f(t)## by ##\cos(3t)##:
\begin{align*}
\digamma\{f(t)\cos(3t)\}(\omega) &= \frac{1}{2} \frac{4}{4 + \left( \omega -3 \right)^2} + \frac{1}{2} \frac{4}{4 + \left( \omega + 3 \right)^2}\\
&= \frac{2}{4 + \left( \omega -3 \right)^2} + \frac{2}{4 + \left( \omega + 3 \right)^2}\\
\end{align*}
\begin{align*}
&- \frac{(2-j\omega)\overbrace{e^{-a(2-j\omega) }}^{\text{Real coefficient goes to zero...}}}{(2+j\omega)(2-j\omega)}
- \frac{(2+j\omega)\overbrace{e^{-a(2-j\omega) }}^{\text{...specifically exp(-2a)}}}{(2+j\omega)(2-j\omega)}\\
\end{align*}
\begin{align*}
\end{align*}
Answer is correct; derivation did not render properly.
There seems to be a math processing error preventing the rendering of the biggest part of this exercise. Looking at the source code, I can't spot the error on my part.
Regradless, if it doesn't decide to resolve itself, the correct answer was
\begin{equation}
\digamma\{ f(t) \} = \frac{4}{4 + \omega^2}
\end{equation}
Thanks for the help, everyone.
Yeah, I'm wondering why that is. I tried to switch any dollar signs to double pound signs and such, but its still not rendering.
Doesn't seem to like the text imbeds
\digamma\{ f(t) \}(\omega) = ## ##\int_{-\infty}^{\infty} e^{-2|u|} e^{-j\omega u} \,du = ## ##\int_{-\infty}^{\infty} e^{-2|u|-j\omega u} \,du## ##
= \int_{-\infty}^{0} e^{2u-j\omega u} \,du + \int_{0}^{\infty} e^{-2u-j\omega u} \,du\\## ##
= \lim_{a \to \infty} \int_{-a}^{0} e^{(2-j\omega) u} \,du + \int_{0}^{a} e^{-(2+j\omega) u} \,du\\## ##
= \lim_{a \to \infty} \left[ \frac{e^{(2-j\omega) u}}{(2-j\omega)}\right]_{-a}^{0} + \left[ \frac{e^{-(2+j\omega)u}}{-(2+j\omega)}\right]_{0}^{a}\\## ##
= \lim_{a \to \infty} \left( \frac{e^0}{(2-j\omega)} - \frac{e^{-a(2-j\omega)}}{(2-j\omega)} \right)+ \left( \frac{e^{-a(2-j\omega) }}{-(2+j\omega)} - \frac{e^0}{-(2+j\omega)} \right)\\## ##
+ \left( \frac{e^{-a(2-j\omega) }}{-(2+j\omega)} + \frac{1}{(2+j\omega)} \right)\\## ##
= \lim_{a \to \infty} \frac{1}{(2-j\omega)} + \frac{1}{(2+j\omega)} - \frac{e^{-a(2-j\omega) }}{(2+j\omega)} - \frac{e^{-a(2-j\omega)}{(2-j\omega)}\\## ##
- \frac{(2+j\omega)\overbrace{e^{-a(2-j\omega) }^{\text{... specifically exp(-2a)}}}{(2+j\omega)(2-j\omega)}\\## ##
\begin{align*}
\end{align*}
Related to How to Fourier-transform e^(-2|t|)?
1. What is the Fourier transform of e^(-2|t|)?
The Fourier transform of e^(-2|t|) is a complex-valued function defined as F(ω) = 2/(4+ω^2), where ω is the frequency variable.
2. How do you perform the Fourier transform of e^(-2|t|)?
The Fourier transform of e^(-2|t|) can be calculated using the integral formula F(ω) = ∫e^(-2|t|)e^(-iωt)dt, where the integration is done over all real values of t.
3. What is the physical interpretation of the Fourier transform of e^(-2|t|)?
The Fourier transform of e^(-2|t|) represents the frequency spectrum of a decaying exponential signal. It shows the amplitude and phase of all the sinusoidal components that make up the original signal.
4. How does the Fourier transform of e^(-2|t|) differ from other Fourier transforms?
The Fourier transform of e^(-2|t|) is unique in that it has a closed-form expression, unlike many other Fourier transforms that require numerical integration. It also has a simple relationship with its inverse transform, making it easier to calculate in both directions.
5. What applications does the Fourier transform of e^(-2|t|) have in science and engineering?
The Fourier transform of e^(-2|t|) is used in many areas of science and engineering, including signal processing, image processing, and quantum mechanics. It is also used in the study of wave propagation and resonance phenomena.
