How to geometrically think of a covector field
  • Thread starter Hymne
  • Tags
    Field
In summary: The composition of two functions is a new function that is obtained by taking the composition of the original functions and applying the composition rule to each component.
Hymne
89
Hello Physicsforums!
It is quite often that I find the geometrical visualization of a covector field as a field where the covector for each point bends along the manifold, M. That is to say it is "contained" in the surface - in contrast to the tangent field in which the vectors streches out from M ... as just tangents. Is there any good site for the justification of this visualization? :/
I am now reading 'Introduction to Smooth Manifolds' by John M. Lee where he writes that every nonzero functional can be determined by its kernel and the hyperplane for which w_p(X) = 1. Futhermore he writes that the kernel is of "codimension-1" - what does this mean?
Let us take the functional [1, 0, 0, 0] for the cotangent space for a point in R^4. If I understood everything this will have a kernel of dimension 3 in the tangentspace spanned by [0, 1, 0, 0]^T, [0, 0, 1, 0]^T and [0, 0, 0, 1]^T. It is not of dimension 1.. Have I missunderstood something fundamental here?
Thanks soooo much!
// Daniel
Yes, you're missing something fundamental. Luckily it's only a definition--your understanding of the mathematics is good. The codimension of a subspace is its dimension subtracted from the dimension of the ambient space. So in your case, codimension 1 is the same as dimension 3, as you computed.
Maybe you were thinking "co"-dimension of the kernel should just mean its dimension in the "co"-tangent space, but that's not the definition.
Aha! That makes much more sense. :)
Lee has however a totally new way of picturing the covariant field than the way I described.. Still I haven't found any mathematical arguments why the one that I described is to prefer or even correct.
It's not very clear what you mean.
It sounds like a foliation, which is problematic because foliations don't always exist, even locally. The big theorem that tells you whether or not there is a foliation is the Frobenius theorem.
One way I would visualize a covector field is just as a plane field of codimension 1, consisting of the kernel of the covector at each point.
You don't need the whole hyperplane, just one vector in it. It's determined by its kernel and its effect on some vector that is not in the kernel. Just basic linear algebra. Take a basis for the kernel, extend it to a basis of the whole tangent space. You know where that basis goes, so you know where everything goes. I guess he mentions the hyperplane because that helps to visualize how far apart the level surfaces are.
Thanks for the answer!
One last question that popped up when I was reviewing though..
Smith writes that a pushforward fulfils: :
[itex](F_* X)(f) = X (f \circ F).[/itex]
Where:
[itex]F: M \rightarrow N[/itex],
[itex]X[/itex] is in [itex]T_pM[/itex],
[itex](F_* X)[/itex] is in [itex]T_{F(p)}N [/itex] and
[itex]f: N \rightarrow[/itex] R
However this means that the righthand side is a derivative that belongs to a tangent space for M acting on a function defined on N... I can't make it add up. It feels like there is a typo in this equation.
I am referring to the following sentence (not found in Smiths book):
When acting on scalar functions, the basis vectors [itex]e_\mu \rightarrow \partial_\mu [/itex] are tangential to the vector space; the 1-forms [itex]\omega^\mu \rightarrow dx^\mu [/itex] lie along it.
(F∗X)(f)=X(f∘F).
Where:
F:M→N,
X is in TpM,
(F∗X) is in TF(p)N and
f:N→ R
The composition is a function from M to R.
When acting on scalar functions, the basis vectors eμ→∂μ are tangential to the vector space; the 1-forms ωμ→dxμ lie along it.
I don't know what he's talking about.
yeah thnx, I honestly don't know what I was thinking..
Do you mean it´s sounds suspicous or that you want more context? :)
Maybe both. What vector space is he talking about?
Hmm, the sentence is taken from a chapter in field theory - so maybe it should be assumed that we are talking about the more relevant spaces in physics, e.g. minkowskispace. But the metric matrix is not choosen and the equations are in their general forms.
There is not much to say.. really. After the above quotation he introduces affine connections, [itex]\Gamma_{\mu \nu}^{\;\;\;\; \lambda}[/itex]. No example is given until the end of the chapter we're euclidean spaces and minkowski space is introduced/reviewed.
The physical applications aren't going to change anything. I was just wondering which vector space he is referring to. Just the tangent space?
I wouldn't take the statement seriously. It's not really important. Just think of a covector as a plane field.
Gah, this whole covector field chapter has made me confused..
Lee writes: [itex]df_p(X_p) = X_pf[/itex].
Now, since [itex]X_p[/itex] is a derivation I assume that I can write the RHS as: [itex]X_p f = v^i \frac{\partial f}{\partial x^i}(p)[/itex], this is obviously vector for which the components are not of infinitesimal order, since we are dividing differentials of order 1 with differentials of order 1.. just like the elementary calculus derivative we could maybe get, let's say: [itex]\frac{\partial f}{\partial x^2}(p) = 3[/itex].
The LHS however looks like differentials! If [itex]df_p =\frac{\partial f}{\partial x^i}(p) dx^i|_p [/itex] are the components of [itex]df_p(X_p)[/itex], can't we somehow just apply:
[itex][\frac{\partial f}{\partial x^1}(p) dx^1|_p, …, \frac{\partial f}{\partial x^n}(p) dx^n|_p] \cdot [v^1 \frac{\partial }{\partial x^1}(p), …, v^n \frac{\partial f}{\partial x^n}(p)]^T[/itex] ?Haha, I think you can see how confused I am here.. The field [itex]df[/itex] is in someway the gradientfield in covector form.. right? I can't get the both sides to add up. The LHS seems to be a vector of infinitesimal order, while the RHS is not.
To summarize the previous post:
It seems like we are setting a vector with infinitesimal components equal to one that is not infinitesimal.
Related to How to geometrically think of a covector field
What is a covector field?
A covector field is a mathematical concept that assigns a covector, which is a linear functional, to each point in a given space. This can be thought of as a collection of covectors that vary smoothly across the space.
How is a covector field different from a vector field?
A vector field assigns a vector to each point in a space, while a covector field assigns a covector to each point. Vectors and covectors are related but have different geometric interpretations. Vectors represent magnitude and direction, while covectors represent the linear functional that acts on vectors.
How can a covector field be visualized geometrically?
A covector field can be visualized as a collection of planes that are tangent to the space at each point. The orientation and magnitude of the planes represent the covector values at each point.
What is the significance of a covector field in mathematics?
Covector fields are important in many areas of mathematics, especially in differential geometry and physics. They are used to define concepts such as gradients, differential forms, and tangent spaces.
How can covector fields be used in practical applications?
Covector fields have many practical applications, such as in fluid dynamics, where they can be used to represent the stress tensor at each point in a fluid. They are also used in computer graphics to represent lighting and shading effects on surfaces.
  • Differential Geometry
