How to get from <P> to probability density P(k)?
In summary: The k integrand is the average momentum, and the k integral integrates over all possible momenta with the weight given by the momentum distribution |\tilde{\psi}(k)|^2, which is the Fourier transform of the probability distribution of position |\psi(x)|^2.
musik132
Knowing the momentum operator -iħd/dx , the expectation value of momentum and the Fourier transforms how can I prove that <p> = ∫dk [mod square of ψ(k)] h/λ. From this, mod square of ψ(k) is defined to be equal to P(k) right?
Momentum operator, p: -iħd/dx
Expectation value of p: <p> = ∫ψ(x)*pψ(x)dx
Fourier transform (not going to type here assuming it is known since it is a lengthy pair of eqs)
I have tried various "tactics" but the closest I got was through these steps. I used the Fourier transforms of ψ(x) and ψ*(x) to get ψ(k) and ψ*(k) somewhere in the eq for <p>. I tried to integrate by parts to pull both ψ(k) out in front so it would form mod square ψ(k). Basically i get as constants ∫[h/(2piλ)][mod square of ψ(k)]*[a large integral]dk. Here is where i got stuck from the solution the integral should equal 2pi which it looks like it doesn't.
Thank you for your time. This problem seems important to know but I just can't find any solutions online.
It's much easier in steps:
(a) Write the position-representation wave function, [itex]\psi(t,x)=\langle x|\psi,t \rangle[/itex] in terms of the momentum-representation wave function, [itex]\tilde{\psi}(t,p)=\langle{p}|\psi,t \rangle[/itex].
(b) Use the result to evaluate [itex]\hat{p} \tilde{\psi}(t,p)[/itex] from the momentum operator in position representation, [itex]\hat{p} \psi(t,x)=-\mathrm{i}/\hbar \partial_x \psi(t,x)[/itex].
(c) Finally write [itex]\langle p \rangle=\langle \psi,t|\hat{p}|\psi,t \rangle[/itex].
Above, I assumed the Schrödinger picture for the time dependence (eigen vectors of position and momentum time-independent state ket time dependent).
How on Earth can anybody check your work if you don't post it? Don't just describe your calculation. Show it. How can we tell if an integral is equal to 2pi if you don't show the integral?
Thanks Vanhees but I have not learned this notation yet which i believe will be the next chapter in the book. Once I get a little bit further ill revisit this calculation to see how this notation might simplify things.
Sorry about not posting the work it is a lot to write without knowing latex. Ill give it a try:
[tex] |\psi(x)|^{2}=P(x) = \psi^*(x)\psi(x)[/tex]
[tex] <p>=\int\psi^*(x)(-i\hbar\frac{\partial}{\partial x})\psi(x) dx[/tex]
Knowing Fourier transforms:
[tex] \psi(x) = \frac{1}{\sqrt {2\pi}}\int_{-\infty}^{\infty}\tilde{\psi}(k)e^{ikx} dk[/tex]
Using the first transform and its complex conjugate we get:
[tex] <p>= \int (\frac{1}{\sqrt {2\pi}}\int_{-\infty}^{\infty}\tilde{\psi^*}(k)e^{-ikx} dk(-i\hbar\frac{\partial}{\partial x})\frac{1}{\sqrt {2\pi}}\int_{-\infty}^{\infty}\tilde{\psi}(k')e^{ik'x}dk') dx[/tex]
I think here is where i messed up since the complex conjugate of a integral might not be the integral of the complex conjugate, but i proceeded anyways
[tex] \int (\frac{k\hbar}{2\pi}\int_{-\infty}^{\infty}\tilde{\psi^*}(k)e^{-ikx} dk \int_{-\infty}^{\infty}\tilde{\psi}(k)e^{ikx}dk) dx[/tex]
This is where I got stuck since integration by parts didn't help me at all. Also did some "illegal" movement of integrals
Edit: I believe I have solved it so ill just post up my solution for anyone that needs it in the future
[tex] \int (\frac{k\hbar}{2\pi}\int_{-\infty}^{\infty}\tilde{\psi^*}(k)e^{-ikx} dk \int_{-\infty}^{\infty}\tilde{\psi}(k')e^{ik'x}dk') dx[/tex]
[tex] \int (\frac{k\hbar}{2\pi} \int_{-\infty}^{\infty}\int_{-\infty}^{\infty}\tilde{\psi^*}(k)\tilde{\psi}(k')e^{ix(k'-k)}dkdk'dx[/tex]
By [tex]\int_{-\infty}^{\infty} e^{ix(k'-k)} = 2\pi\delta(k'-k)[/tex]
This was what I was missing
We get:
[tex]k\hbar\int_{-\infty}^{\infty}\tilde{\psi^*}(k)\tilde{\psi}(k')\delta(k'-k)dkdk'[/tex]
[tex]k\hbar\int|\psi(k)|^2dk[/tex]
You started very well! It's important to keep different labels for the [itex]k[/itex] and [itex]k'[/itex] integrals, before you do the [itex]x[/itex] integration. At the end, of course, the [itex]k[/itex] must be under the [itex]k[/itex] integral to get the average momentum. As for any distribution, the expectation value is given by (using [itex]p=\hbar k[/itex])
[tex]\langle p \rangle=\int_{\mathbb{R}} \mathrm{d} k \; \hbar k \; \tilde{P}(k).[/tex]
Related to How to get from <P> to probability density P(k)?
What is a probability density function?
A probability density function, or PDF, is a mathematical function that describes the relative likelihood of a continuous random variable taking on a certain value. It can be used to determine the probability of a variable falling within a specific range of values.
What is the difference between a PDF and a probability distribution?
A probability distribution is a function that describes the probability of different outcomes occurring for a discrete or continuous random variable. A PDF specifically refers to the probability distribution for a continuous random variable.
What is the relationship between a PDF and a cumulative distribution function (CDF)?
The PDF and CDF are closely related, with the CDF being the integral of the PDF. The CDF gives the probability that a continuous random variable will take on a value less than or equal to a specified value, while the PDF gives the probability that the variable will take on a specific value.
How is a PDF calculated?
The exact method for calculating a PDF will depend on the specific probability distribution being used. For some distributions, such as the normal distribution, there are well-known formulas for calculating the PDF. For others, it may be necessary to use numerical methods or computer software to estimate the PDF.
What is the importance of understanding PDFs in scientific research?
PDFs are important in scientific research because they allow us to model and analyze data that follows a continuous distribution. This can be useful in fields such as statistics, physics, and engineering, where data often follows a continuous distribution. Understanding PDFs can also help us make predictions and draw conclusions about the likelihood of certain outcomes occurring.
