How to get the balanced redox equation in this sample problem?
In summary, our chemistry teacher gave a sample problem regarding balancing a redox equation. I managed to proceed to a considerable distance, but I can't seem to understand how to get the final balanced equation. Please help me out.
nineteen
68
Moved from a technical forum
Summary: Our chemistry teacher gave a sample problem regarding balancing a redox equation. I managed to proceed to a considerable distance, but I can't seem to understand how to get the final balanced equation. Please help me out.
The problem is; reaction of K2Cr2O7 with SO2 in the presence of H2SO4(aq) giving Cr3+ ions and SO4 ions as main products.
I could complete the following steps :
Oxidation half reaction : SO2 ------------------ > SO4
Reduction half reaction : Cr2O72- ------------------- > Cr3+
2H2O + SO2 ------------------ > SO4 + 4H+ + 2e-
6e- + 14H+ + Cr2O72- ------------------- > 2Cr3+ + 7H2O
Then I multiplied the "2H2O + SO2 ------------------ > SO4 + 4H+ + 2e-" equation by three so that I can add the both equations by equalizing the electron amount.
Then I added the both like this...
6H2O + 3SO2 + 14H+ + Cr2O72- ------ > 3SO4 + 12H+ + 2Cr3+ + 7H2O
Then simplified it into this :
2H+ + Cr2O72- + 3SO2 -----> 2Cr3+ + 3SO4 + H2O
But the ultimate balanced equation that I should get is,
H2SO4(aq) + K2Cr2O7(aq) + 3SO2(g) ------ > Cr2(SO4)3(aq) + K2SO4(aq) + H2O(aq)
right?
How can I proceed to get the ultimate balanced equation? I can't understand how to do it. Please help me on this. Thank you very much in advance.
You need to add a bunch of spectators. Start by writing chromium sulfate on the right in the molecular form, then add potassium cations and sulfate anion on the left to convert ions to other molecules, and the same amount on the right to keep the reaction balanced.
Likes nineteen
What are spectators? And why should we add them?
Do you know the difference between net ionic reactions and complete reactions?
Likes nineteen
Yes. Just after you mentioned, I did a small research and found out about the both types of reaction equations. I have a small idea about spectators now. They are just like normal conventional spectators in a game show, they are watching at what happens in a reaction, and also with them only, the ones that react to form a complete product come with. Isn't it?
So why do we need to add a couple of spectators here?
nineteen said:
Oxidation half reaction : SO2 ------------------ > SO42ˉ
Having not yet checked to see what you took care of yet, my suggestion with these two half-reactions is this:
  1. Balance each of the two for at least the atom which changes in charge; and then include the necessary number of electrons in each half-reaction.
  2. Now balance the two half reactions together for the number of electrons. What this is supposed to mean, is to make sure to adjust one or both half reactions so they each use the same number of electrons.
Once that is done, you can take care of the rest of the balancing of atoms or ions.
Likes nineteen
When you compare the reaction you are asked to give as a final solution with the reaction you already have, it is apparent spectators are missing. For example - you should have K on both sides, as a cation in a salt. There are no K+ in the net ionic reaction that you have balanced - so you need to add them. As long as you add the same number of them on both sides, reaction will be still balanced.
This is just the opposite of the process of preparing the net ionic reaction - typically you start with a full reaction and cancel out ions/moles that didn't change. Here you have to bring them back.
Likes jim mcnamara and nineteen
Thank you for showing me the way. Really appreciate it @Borek ...
Thank you @symbolipoint
Related to How to get the balanced redox equation in this sample problem?
1. How do I identify the oxidation and reduction half-reactions in a redox equation?
In order to identify the oxidation and reduction half-reactions, you must first assign oxidation numbers to each element in the equation. The element that is oxidized will have an increase in oxidation number, while the element that is reduced will have a decrease in oxidation number.
2. What is the purpose of balancing a redox equation?
The purpose of balancing a redox equation is to ensure that the number of atoms of each element and the total charge is the same on both sides of the equation. This allows for a more accurate representation of the chemical reaction.
3. How do I balance a redox equation using the half-reaction method?
To balance a redox equation using the half-reaction method, first balance the atoms of each element in each half-reaction. Then, balance the charges by adding electrons to one side of the equation. Finally, multiply each half-reaction by a coefficient to ensure that the number of electrons is the same in both half-reactions.
4. Can I balance a redox equation using the oxidation number method?
Yes, it is possible to balance a redox equation using the oxidation number method. This method involves assigning oxidation numbers to each element, determining which elements are oxidized and reduced, and then balancing the equation by adding or subtracting electrons and adjusting coefficients.
5. Are there any shortcuts or tricks to balancing redox equations?
While there are no shortcuts, there are some tips and tricks that can make balancing redox equations easier. These include balancing atoms of elements that appear in only one half-reaction first, using the lowest common multiple to balance the number of electrons, and checking the final equation to ensure that all atoms and charges are balanced.
10K
