I How to get the energy eigenvalue of the Hamiltonian: H0+λp/m ?
Jiangwei Du
TL;DR Summary
We have already know the energy eigenvalue E0 of initial Hamiltonian H0. So when we add the extra item-λp/m, how the energy eigenvalue will vary?
Someone says we can choose the new eigenstate: exp(-iλx/hbar)*ψ,and let the momentum operator p acts upon this new state. At the same time, so does p^2. Something miraculous will happen afterwards. My question is: how to image this point? Thank you very much.
The idea here is that when the momentum operator p is applied to an eigenstate, it will produce a state with the same energy (eigenvalue) as before. However, when the momentum operator squared, p^2, is applied to this same eigenstate, the result will be a state with a different energy. This is because the momentum operator squared contains additional terms corresponding to higher powers of momentum, which require higher energies to produce states with the same eigenvalue. This is an example of what is known as "quantum tunneling", where particles can pass through "barriers" of energy which would normally be too high to be overcome. In this case, the particle is able to "tunnel" through the barrier by utilizing the energy associated with its momentum.
Likes Jiangwei Du
Sorry, I can't understand your statement. Maybe you have strayed from the point.
Jiangwei Du said:
Someone says
Where? Please give a reference.
You can try to complete the square.
Jiangwei Du said:
TL;DR Summary: We have already know the energy eigenvalue E0 of initial Hamiltonian H0. So when we add the extra item-λp/m, how the energy eigenvalue will vary?
You can establish a linear dispersion relation with a term like ##v \mathbf{\sigma} \cdot \mathbf{p}## and you can add it your p^2 term to get some generalised k.p approximation useful for some semiconductors/semimentals. Is this what is motivating your question?
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
