How to get this 2 dimensional equation
  • Thread starter superyoo
In summary, the range R can be expressed in terms of the maximum height h, and in particular that R=4hcotθ.
superyoo
Show that the range R can be expressed in terms of the maximum height h, and in particular that R = 4hcotθ. (b) Show that, when the range is a maximum, h = R/4
R = ( V0^2sin(2θ) ) / g
V0^2 = ( (1/4)g^2t^4+R^2 ) / t^2
Vy = Vy0 - gt
R represents displacement or range, v0 represents the initial velocity, g represents gravity, t is time and vy0 represents the y component.
I tried approximately for 4 hours and still couldn't get it. It would be very nice if someone helps me.
Thanks a lot.
ps Its due tomorrow
Forum rules require you to post an attempt at the solution before receiving help. So let's see what you've got so far.
I tried many different times.
My last try :
http://www.webforone.com/images/ko1w9b5lze83cqfl4ujx_thumb.pngI didn't scan all my tries because I want to make sure that someone in this website knows the answer for this question, before I spend my time in scanning my work.
Welcome to PF.
First of all make your Range equation less complicated and undo the sin2θ to 2sinθcosθ.
Now I see you derived an expression for H in terms of Vo*sinθ - eliminating t from the equation
h = 1/2*g*t2
So look carefully at your expanded range equation and see how you might make a substitution.
Thanks for posting your work. After looking it over, I have a better way to do this.
1.) The maximum height occurs when [itex]x=\frac{R}{2}[/itex] (that is when the projectile has covered half of its range). Set [itex]x(t)=v_0\cos(\theta)t[/itex] equal to [itex]\frac{R}{2}[/itex] and solve for [itex]T[/itex]. This is the time at which the particle reaches its maximum height. You should be able to show that:
[tex]T=\frac{v_0\sin(\theta)}{g}[/tex]
Don't forget that [itex]\sin(2\theta)=2\sin(\theta)\cos(\theta)[/itex].
2.) Plug this [itex]T[/itex] into the equation for [itex]y(t)=v_0\sin(\theta)t-\frac{1}{2}gt^2[/itex]. This will give you the maximum height [itex]H[/itex].
Combine this equation for [itex]H[/itex] with the equation for [itex]R[/itex] to obtain the result. I did it very quickly by eliminating [itex]g[/itex] in the first one and plugging into the second one.
Follow my steps and you'll have this done in plenty of time to catch South Park. :biggrin:
FAQ: How to get this 2 dimensional equation
How do I convert a 3-dimensional equation into a 2-dimensional one?
To convert a 3-dimensional equation into a 2-dimensional one, you can simply eliminate one of the variables by setting it equal to a constant. This will result in a 2-dimensional equation with only two variables.
Can I plot a 2-dimensional equation in a 3-dimensional graph?
No, a 2-dimensional equation can only be plotted on a 2-dimensional graph. A 3-dimensional graph requires an equation with three variables.
How do I determine the number of dimensions in an equation?
The number of dimensions in an equation is equal to the number of variables present. For example, an equation with x, y, and z variables is in 3 dimensions.
Is it possible to solve a 2-dimensional equation without graphing it?
Yes, it is possible to solve a 2-dimensional equation without graphing it. You can use algebraic methods such as substitution or elimination to solve for the variables.
What is the difference between a 2-dimensional and a 2-variable equation?
A 2-dimensional equation refers to an equation with two dimensions, typically x and y. A 2-variable equation refers to an equation with two variables, which can be in any number of dimensions. For example, an equation with x and y variables can be in 2 or 3 dimensions.
