mathbrah
- 1
how would one see the first
and come up with the second
In order to simplify an expression like 2*4*6 (2n), you can use the power rule, which states that when multiplying powers with the same base, you can add the exponents. In this case, we can rewrite 2*4*6 (2n) as 2^1 * 2^2 * 2^3 * 2^n. Then, using the power rule, we can simplify this to 2^(1+2+3+n) = 2^(6+n).
To convert an expression from 2*4*6 (2n) to (2^n)n, we can use the commutative property of multiplication, which states that the order of multiplication does not change the result. Therefore, we can rewrite the expression as 2^n * 2^(n+1) * 2^(n+2) = (2^n)^3 = (2^n)n.
The rule for simplifying expressions with exponents is the power rule, which states that when multiplying powers with the same base, you can add the exponents. This can also be extended to dividing powers with the same base, where you can subtract the exponents.
Exponential growth occurs when a quantity increases exponentially over time. In this expression, as the value of n increases, the value of 2^n also increases significantly. For example, when n=0, 2^n = 2^0 = 1. But when n=5, 2^n = 2^5 = 32. This shows that as n increases, the value of 2^n grows exponentially.
This expression can be used in various real-world applications, such as in finance and population growth. In finance, it can be used to calculate compound interest, where n represents the number of compounding periods. In population growth, it can be used to model the growth of a population over time, where n represents the number of generations.
