How to improve the efficiency of a propeller?
In summary: So the higher the aspect ratio the less effect the inefficient tip part has on overall performance. It's one reason why gliders have high aspect ratio wings.
PhyIsOhSoHard
158
One of your friends is building his own airplane. He has received a quotation for a two-bladed propeller with an efficiency of ##\eta = 80\%## . He asks for your advice on whether it is possible to get a higher efficiency - what is your answer?
  • no, the efficiency based on physics not be improved
  • use a large diameter propeller
  • use a propeller with more blades
  • use a higher rotational speed
  • use propeller blades with a larger chord
The correct answer according to my book is "use a large diameter propeller" however his propeller already has an efficiency of 80%, is it physically possible to make it higher than this?
Here is a graph that shows the efficiency of an aircraft but it doesn't go higher than 80% efficiency:
So how is it possible to increase this efficiency by making the diameter larger?
For the record, the speed of advance coefficient (J) is:
##J=\frac{V}{nD}##
Where V is the velocity of the aircraft, D is the diameter and n is the revolutions.
The graph shows how the efficiency depends on speed, (for a fixed diameter).
A larger diameter may move more air with a smaller increase in drag compared with the other approaches.
But it may not translate into gains against the advance coefficient.
If you increase D, you decrease J ... what happens to ##\eta (J)##?
iirc - 80% is pretty close to the top efficiency of a prop.
The ideas in your OP might give you more power or thrust, but not higher efficiency. You will need a more powerful motor to drive the bigger/faster prop.
You can't make a prop that is 100% efficient, because it can only generate thrust by moving air about, and some energy must be "wasted" in the propellor wake left behind the plane.
Assuming V is to be the same, then n would need to be decreased if D is increased, and J could end up being the same, and the curve for ##\eta (J)## might shift upwards by a small amount. If the propeller is already at 80% efficiency, then it's probably at a point of diminishing returns for increasing D.
@rcldr: thanks but - that question was pedagogical - I know what I'd answer ... I want to see what OP answers.
Comes down to how you interpret the question though doesn't it?
Take each choice in turn - all of them have something objectionable about them.
One simple explanation for the book answer is that the tips of any wing are less efficient than the mid span. So the higher the aspect ratio the less effect the inefficient tip part has on overall performance. It's one reason why gliders have high aspect ratio wings.
Related to How to improve the efficiency of a propeller?
1. How does the shape of a propeller affect its efficiency?
The shape of a propeller, including its size, number of blades, and angle of the blades, plays a crucial role in determining its efficiency. A well-designed propeller will create maximum thrust with minimum drag, resulting in better efficiency.
2. Can changing the material of a propeller improve its efficiency?
Yes, the material of a propeller can have a significant impact on its efficiency. Lighter materials, such as carbon fiber, can reduce the weight of the propeller and improve its efficiency. Additionally, using materials with low friction can also improve the propeller's efficiency.
3. How does the speed of rotation affect the efficiency of a propeller?
The speed of rotation is a critical factor in determining the efficiency of a propeller. As the speed increases, the propeller creates more thrust, but it also experiences more drag. Therefore, finding the optimal speed for a particular propeller design is crucial for maximizing its efficiency.
4. Can adjusting the pitch of a propeller improve its efficiency?
Yes, adjusting the pitch of a propeller can improve its efficiency. By changing the angle of the blades, the propeller can generate more or less thrust, depending on the desired speed and load. This adjustment can help optimize the propeller's performance and improve its efficiency.
5. How can regular maintenance help improve the efficiency of a propeller?
Regular maintenance, such as cleaning and polishing the propeller, can help improve its efficiency. Over time, propellers can accumulate debris and damage, which can affect their performance. By keeping the propeller in good condition, it can function at its best and maintain its efficiency.
  • Other Physics Topics
11K
  • Classical Physics
  • Mechanical Engineering
