How to include two header files that are contained in the same folder?
  • Thread starter Thread starter Eclair_de_XII
    files
The discussion centers around issues with including header files and linking a C++ library using the GNU C Compiler. A user encounters a "not found" error when trying to include "header_one.h" and seeks clarification on whether the compiler is misinterpreting the include paths. It is highlighted that the correct command for compiling should specify both the library and header file locations, using the appropriate flags for linking. The importance of avoiding multiple inclusions of header files is emphasized, with suggestions for using include guards or the `#pragma once` directive. The conversation reflects the complexities of managing dependencies in C++ and the challenges faced by users when linking libraries.
Eclair_de_XII
TL;DR Summary
Let's say I have a directory called "headers". Contained in that directory are two files, "header_one.h" and "header_two.h". The former defines an "add" function that the latter uses in order to define a "subtract" function. Let's say we have a source file that is one level below "headers", "sample.c" that #include's "header_two.h". How would I compile the program without gcc complaining about not being able to find "headers/header_one.h"?
[CODE lang="c" title=".headers/header_one.h"]int add(int x, int y){
return x+y;
}[/CODE]
[CODE lang="c" title="./headers/header_two.h"]#include "headers/header_one.h"
int subtract(int x,int y){
return add(x,-y);
}[/CODE]
[CODE lang="c" title="./sample.c"]//#include "headers/header_one.h"
#include "headers/header_two.h"
int main(void){
return 0;
[/CODE]
If I run this, the compiler tells me that "headers/header_one.h" is not found. I don't understand why this is. Is it assuming that I'm #include-ing "header_one.h" from "headers/header_two.h", instead of from "sample.c"?
The reason I bring this up is because I am having great difficulty linking a C++ library to my programs. The problem presented above is one of the workarounds I came up with. But the true problem is as follows:
I just installed a C++ library, but I'm having trouble linking it to a sample program using the GNU C Compiler. The command I'm using in order to compile my program is "g++ main.cc -L './installed/x64_linux/include' -l 'cpr/cpr'; ". But the compiler doesn't seem to be able to compile the sample program that I copy-pasted from the official website of the library.
This would be the script that I used in order to download the package.
Bash:
git clone https://github.com/Microsoft/vcpkg.git
cd vcpkg
./bootstrap-vcpkg.sh
./vcpkg integrate install
./vcpkg install cpr
This would be the program that I'm trying to compile from the directory "./vcpkg".
[CODE lang="cpp" title="./vcpkg/main.cc"]#include <cpr/cpr.h>
//#include "cpr/cpr.h" // Complains about a missing "cpr/api.h" file
int main(int argc, char** argv) {
cpr::Response r = cpr::Get(cpr::Url{"https://api.github.com/repos/libcpr/cpr/contributors"},
cpr::Authentication{"user", "pass", cpr::AuthMode::BASIC},
cpr::Parameters{{"anon", "true"}, {"key", "value"}});
r.status_code; // 200
r.header["content-type"]; // application/json; charset=utf-8
r.text; // JSON text string
// https://docs.libcpr.org/[/CODE]
Technology news on Phys.org
-L is for specifying a location to look for library files in. Usually your libraries are in a folder called lib or lib64 and header files are in a folder called include. To specify the location of your header files, use -<capital i> <path where your headers folder is>.
e.g. it should look something like this:
g++ main.cc -L ./installed/x64_linux/lib/cpr -lcpr -l ./installed/x64_linux/include
Where the first -l is a lowercase L and the second is an upper case i.
This assumes you have your libaray file in ./installed/x64_linux/lib/cpr.
Thank you. Your post was most informative. However, for some odd reason, my "ld" program keeps saying that it cannot find the "cpr/cpr" library. I am well-aware that this is not a technical forum for me to ask questions about a specific library, so I think it is reasonable to not ask further about my technical difficulties, which I would be able to resolve if only I would learn C++ properly.
Thanks for the help. I found out that I had to link all the dependencies of the "cpr" library/header, in addition to "cpr" itself.
g++ main.cc -L ./installed/x64_linux/lib/ -I ./installed/x64_linux/include/ -lcpr -lcurl -lssl -lcrypto -lz -lpthread
It's unwieldy to have to include all these libraries in order to use just the one. I think there should be a better way. I was just linking the libraries as indicated in the library directory, and skimming through the error messages I received in order to obtain a functioning compilation command. Trial-and-error isn't exactly a good technique in this field I should think, but in my exhaustion, I was getting pretty desperate.
On a second note:
Function declarations are commonly placed in header files (*.h). so:
[CODE lang="c" title="./headers/header_one.h"]int add(int x, int y);
[/CODE]
int subtract(int x,int y);
[/CODE]
Then the function definitions are placed in a c file:
[CODE lang="c" title="./math.c"]
return x+y;
return add(x,-y);
[/CODE]
One notable exception to this rule are "inline" functions. But I'm guessing you haven't encountered any of those yet.
On a third note:
Your header_two.h includes header_one.h - a common occurrence in c programming.
But it means that had math.c included both of those, header_two.h would have been included twice.
In general, including a header file twice is inviting trouble, so this is how that is handled:
#ifndef _HEADER_TWO_INCLUDED_
#define _HEADER_TWO_INCLUDED_
#endif // _HEADER_TWO_INCLUDED_
[/CODE]
Or, if your compiler supports the #pragma once directive:
#pragma once
[/CODE]
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
