How to increase COP and SCP of the absorption chiller
In summary, the speaker is asking for ideas on how to increase the COP and SCP of a silica gel absorption chiller. They currently have two beds of silica gel and are unable to purchase extra beds or change to a bigger size. They are wondering if changing the heat exchanger or other methods could improve efficiency. The speaker also clarifies that it should be adsorption, not absorption, and apologizes for the mistake. They suggest contacting the manufacturer for ideas and clarification on the terminology.
QFGreg
Dear all,
I would to like to ask do anyone have any idea on how to increase the COP and SCP(Specific Cooling Power) of a silica gel absorption chiller?
COP= Heat removed by evaporator/ Heat supplied to system( normally is the hot water supplied to the absorption bed)
SCP= heat removed at evaporator/ mass of silica gel( 1 kg silica gel is being used in the experiment)*cycle time
Currently we have two bed of silica gel absorption bed, neither the faculty is willing to purchase extra absorption bed( which able to reduce the cycle time) nor change a bigger size of absorption bed ( which able to increase the mass of the silica gel to be put inside ).
I am wondering what can i do else to improved the efficiency, perhaps to change the better heat exchanger or anything else? @.@
Thank you everyone
I would contact the manufacturer of the exchanger itself, they'll have the best ideas for their specific model.
Also, are you sure it's not adsorption? With Silica gel, I'd expect this to be an adsorption unit. Just trying to ensure you are using the proper term when discussing this in the future, as the two processes operate differently.
Sorry should be adsorption... Typed wrongly... Tq
Related to How to increase COP and SCP of the absorption chiller
1. What is COP and SCP?
COP stands for Coefficient of Performance, which is a measure of the efficiency of an absorption chiller. SCP stands for Specific Cooling Power, which is a measure of the chiller's ability to produce cooling in a given time period.
2. Why is it important to increase COP and SCP?
Increasing COP and SCP can lead to cost savings and improved performance of the absorption chiller. A higher COP means the chiller is using less energy to produce the same amount of cooling, while a higher SCP means the chiller can produce more cooling in a shorter amount of time.
3. How can I increase the COP and SCP of an absorption chiller?
There are several ways to increase COP and SCP, including regularly maintaining the chiller, using higher quality materials, optimizing the design of the chiller, and implementing energy-saving technologies such as variable speed drives and heat recovery systems.
4. Can I increase COP and SCP without making major changes to the chiller?
Yes, there are several smaller adjustments that can be made to improve COP and SCP. These include adjusting the refrigerant charge, optimizing the operating conditions, and implementing control strategies to reduce energy consumption.
5. Are there any downsides to increasing COP and SCP?
In some cases, increasing COP and SCP may require additional investments or changes to the chiller system. It's important to carefully evaluate the cost-benefit analysis before making any changes. Additionally, increasing COP and SCP may also lead to higher maintenance costs or more frequent replacements of certain components.
  • Mechanical Engineering
  • Electrical Engineering
