How to install x11 headers on android?
In summary, the conversation is discussing the possibility of compiling a C code on an Android device that lacks x11 headers. One suggestion is to cross compile the code on a Linux system and transfer the executable to Android. The speaker also mentions that Android likely has similar functionality to X11.
jk22
729
24
Hello,
I'm using cppdroid and wrote a c code running a window on x11 (originally Ubuntu Linux) and installed a xserver on android. How could i compile this code on Android knowing it lacks the x11 headers ? Thanks.
Technology news on Phys.org
Maybe this is a silly suggestion, but would it be possible (and easier) to cross compile?
I don't know what you mean by this. Is it to compile under linux and put the executable on android ?
Yes. Many compilers will let you specify the target architecture of code you're compiling. Ordinarily, when your compiler is running on a particular OS, the code you compile will run on that same OS. A cross compiler will generate code that will run under a different OS/architecture.
I'm not familiar with X11, but if your code is intended to run on Android, I'm reasonably sure it has the same or similar functionality as is available in X11.
Related to How to install x11 headers on android?
1. What is X11 headers on Android?
X11 headers on Android are a set of files that contain the interface definitions and function prototypes for the X11 windowing system. They allow developers to access and use the X11 libraries when creating applications for Android.
2. Why do I need to install X11 headers on Android?
You need to install X11 headers on Android if you want to develop applications that use the X11 windowing system. These headers are necessary for compiling and linking your code with the X11 libraries.
3. How can I install X11 headers on Android?
To install X11 headers on Android, you will need to use a package manager such as APT or YUM. First, make sure your device is rooted and has a custom recovery installed. Then, download the necessary X11 header package and install it using the package manager.
4. Can I install X11 headers on any Android device?
No, not all Android devices support the installation of X11 headers. Your device must be rooted and have a custom recovery installed in order to install these headers. Additionally, some devices may not have the necessary hardware or drivers to support the X11 windowing system.
5. Are there any alternatives to installing X11 headers on Android?
Yes, there are alternative ways to develop applications that use the X11 windowing system on Android. One option is to use a compatible X11 server app that can be installed on your device. Another option is to use a cross-platform development tool, such as Qt, which has built-in support for the X11 libraries.
