How to Integrate $\int(e^{t^2}+16)te^{t^2} dt$ Using Substitution?
  • MHB
  • Thread starter karush
In summary: Therefore, the integral is $\int (e^{2t^2}+ 16)e^{2t^2}(e^{t^2}+ 16) dt= \frac{1}{4}e^{2t^2}+ 8e^{t^2}+ C$.
karush
MHB
3,269
mnt[s8.4.4.1\\8.7.3\\6.4} whit \nmh{362}
Evaluate $\int(e^{t^2}+16)te^{t^2} dt$
was going to distribute but not sure if a substitution would be better
the answer looks like it is done by observationW|A returned
pretty easy to see the derivative of $(e^{t^2} + 16)$ is $2t e^{t^2}$ ... all one needs is the constant $2$ with $\dfrac{1}{2}$ outside the integral to set it up
$\displaystyle \dfrac{1}{2} \int (e^{t^2}+16) \cdot 2te^{t^2} \, dt = \dfrac{1}{2} \int u \, du$
To integrate $\int (e^{t^2}+ 16)te^{t^2}dt$. It should be obvious that the "$t^2$ in $e^{t^2}$ is the "problem" since $e^{t^2}$ alone does not have an elementary anti-derivative. So cross your fingers and let "$u= t^2$". Then $du= 2t dt$. Alright! There is a "t" in the integrand!
We can the integral as $\int (e^{t^2}+ 16)e^{t^2}(tdt)$ and since, with the substitution $u= t^2$, $du= 2tdt$, so that $tdt= \frac{1}{2}du$ the integral becomes $\int (e^u+ 16)e^u (\frac{1}{2}du)= \frac{1}{2}\int (e^u+ 16)e^u du$. And, looking at that and remembering that at the derivative of $e^u$ is just $e^u$ again, make another substitution, $v= e^u$ o so that $dv= e^u du$ and the integral becomes $\frac{1}{2}\int (v+ 16)dv$.
(If I were very clever I would have thought of the substitution $v= e^{t^2}$ immediately but I have to do things step by step.)
That's easy to integrate! $\frac{1}{2}\int (v+ 16) dv=\frac{1}{2}(\frac{1}{2}v^2+ 16v)+ C= \frac{1}{4}v^2+ 8v+ C$ where "C" is the "constant of integration".
But now we have to go back to the original variable, t. Since $v= e^u$, $\frac{1}{4}v^2+ 8v+ C= \frac{1}{4}(e^u)^2+ 8e^u+ C= \frac{1}{4}e^{2u}+ 8e^u+ C$. And since $u= t^2$, $\frac{1}{4}e^{2u}+ 8e^u+ C= \frac{1}{4}e^{2t^2}+ 8e^{t^2}+ C$.
FAQ: How to Integrate $\int(e^{t^2}+16)te^{t^2} dt$ Using Substitution?
What does "-w.8.7.3 int with e" mean?
"-w.8.7.3 int with e" is a notation used in scientific and mathematical calculations to indicate a number with a specific precision. The "w" represents the width of the number, the "8" represents the number of digits before the decimal point, the "7" represents the number of digits after the decimal point, and the "3" represents the number of digits to be displayed. The "int" indicates that the number is an integer, and the "e" signifies scientific notation.
How do you convert a number written in "-w.8.7.3 int with e" notation to standard form?
To convert a number written in "-w.8.7.3 int with e" notation to standard form, you can use the following formula:
Number = w x 10^(e-1)
where w is the number before the "e" and e is the exponent after the "e". For example, if you have the number "-5.123e4", the standard form would be -5.123 x 10^(4-1) = -5.123 x 10^3 = -5123.
How is "-w.8.7.3 int with e" notation different from scientific notation?
The main difference between "-w.8.7.3 int with e" notation and scientific notation is that "-w.8.7.3 int with e" includes the number of digits to be displayed (represented by the "3" in the notation). This allows for more precise calculations and avoids rounding errors. Additionally, "-w.8.7.3 int with e" notation is commonly used in computer programming and engineering, while scientific notation is more commonly used in scientific and mathematical calculations.
Can you perform mathematical operations on numbers written in "-w.8.7.3 int with e" notation?
Yes, you can perform mathematical operations on numbers written in "-w.8.7.3 int with e" notation. However, it is important to keep in mind the precision of the numbers and to use appropriate rounding methods to avoid errors in the final result.
How do you represent very large or very small numbers using "-w.8.7.3 int with e" notation?
"-w.8.7.3 int with e" notation is commonly used to represent very large or very small numbers, as it allows for a high level of precision. For example, a very large number such as 1.23456789 x 10^20 would be written as 1.23456789e20 in "-w.8.7.3 int with e" notation. Similarly, a very small number such as 0.0000000123456 would be written as 1.23456e-8 in "-w.8.7.3 int with e" notation.
