How to Integrate tan 2x?
In summary, the integral of tan 2x is equal to the integral of sin 2x over cos 2x, which can be rewritten as the integral of 2 sin x cos x over 1 - 2 sin^2 x. By letting u = sin x, we can rewrite the integral as the integral of 2u over 1 - 2u^2, which can then be simplified using integration techniques. Alternatively, we can use u = 2x to make the integral easier to solve. Expanding sin 2x and cos 2x in terms of sin x and cos x just adds unnecessary complexity. Another option is to let v = 1 -
askor
169
What is ##\int \tan 2x \ dx##?
What I get is
##= \int \frac{\sin 2x}{\cos 2x} dx##
##= \int \frac{2 \sin x \cos x}{1 - 2 \sin^2 x}dx##
let u = sin x then ##\frac{du}{dx} = \cos x## or du = cos x dx
So
##= \int \frac{2u}{1 - 2u^2} du##
What I get is
So
There may be easier ways to do this, but since you tried it this way, notice that ##2u du= -\frac{1}{2}d(1-2u²)##
What I get is
So
Rather than saying u = sin x, use u = 2x instead. Just expand tan u into ##\frac{sin\, u}{cos\, u}##.
This integral is much easier to solve.
Expanding sin 2x and cos 2x in terms of sin x and cos x just makes things more complicated.
What I get is
So
Let ##v= 1- 2u^2## so that ##dv= -4u du##. Then ##(-1/2)dv= 2u du## and the integral becomes ##-\frac{1}{2}\int \frac{dv}{v}##
Related to How to Integrate tan 2x?
1. What is the definition of integral tan 2x dx?
The integral of tan 2x dx is the inverse of the derivative of tan 2x. In other words, it is the function that, when differentiated, yields tan 2x.
2. How do you solve for the integral of tan 2x dx?
To solve for the integral of tan 2x dx, you can use the substitution method or integrate by parts. The most common approach is to use the substitution method, where you let u = 2x and du = 2dx.
3. What are the steps to evaluating the integral of tan 2x dx?
The steps to evaluating the integral of tan 2x dx are as follows:
  1. Use the substitution method by letting u = 2x and du = 2dx.
  2. Transform the integral into the form of tan u du.
  3. Integrate using the basic integral formula for tan u.
  4. Substitute back in the original variable x to get the final answer.
4. Is there a general formula for solving the integral of tan 2x dx?
Yes, the general formula for solving the integral of tan 2x dx is:
∫ tan 2x dx = (1/2) ln|sec 2x| + C
5. How is the integral of tan 2x dx used in real-life applications?
The integral of tan 2x dx has many applications in physics and engineering, particularly in the fields of vibrations and oscillations. It is also used in signal processing and electrical engineering to analyze and manipulate signals. Additionally, it has applications in geometric optics, where it is used to find the path of light rays through optical systems.
  • Calculus
  • Calculus
  • Calculus
