How to interpret advection (v.del) v->v.(del v)
  • Thread starter Thread starter Monty Hall
The discussion focuses on understanding the convective acceleration term in the Navier-Stokes equation, specifically the expression (\mathbf{v}\cdot\nabla)\mathbf{v}. There is confusion regarding the notation, particularly how \nabla \mathbf{v} relates to the Jacobian matrix and why the expression results in a vector. The participants clarify that in index notation, the operation can be expressed as v_{j}\frac{\partial{v}_{i}}{\partial{x}_{j}}, which indicates a matrix operation. The equivalence of (v.del)v and v.del(v) is also examined, with a focus on reconciling the vector and matrix interpretations. Overall, the conversation seeks clarity on the mathematical terminology and relationships within the context of fluid dynamics.
Monty Hall
I'm looking @ convective accerlation term in http://en.wikipedia.org/wiki/Navier_stokes_equation#Convective_acceleration. I don't understand the terminology. If v is a vector, it says that (\mathbf{v}\cdot\nabla)\mathbf{v} can be written as \mathbf{v}\cdot\nabla \mathbf{v}. I thought that \nabla \mathbf{v} is the transpose of the Jacobian matrix for \mathbf{v}. As I'm not familiar with the terminology it almost looks like (\mathbf{v} \cdot \nabla \mathbf{v} = vector . matrix), which can't be right. However, it appears (v\cdot\nabla)v is a vector. Can somebody shed some light on how v\cdot\nabla v is a vector? If (\mathbf{v}\cdot\nabla)\mathbf{v}=\mathbf{v}\cdot\nabla \mathbf{v} & \nabla \mathbf{v} = (\mathbf{J}\mathbf{v})^T. I'm sure I'm mutilating the terminology, if anybody could shed light on this, much appreciated.
Mathematics news on Phys.org
In index notation, we have:
\vec{v}\cdot\nabla=\sum_{j=1}^{3}v_{j}\frac{\partial}{\partial{x}_{j}}
where the indices ought to be fairly self-evident.
Usually, we just omit the summation symbol, writing v_{j}\frac{\partial}{\partial{x}_{j}} instead.
Setting this alongside a vector v_{i} then, we have:
(\vec{v}\cdot\nabla)\vec{v}=(v_{j}\frac{\partial}{\partial{x}_{j}})v_{i}=v_{j}\frac{\partial{v}_{i}}{\partial{x}_{j}}
The quantity \frac{\partial{v}_{i}}{\partial{x}_{j}} is a matrix
Thanks for your reply, I've seen that as well the (v.del) makes a lot more sense. I know (v.del)v should equal v.del(v), but I'm curious how can I come to same result starting with v.del(v) which to me looks like a vector.matrix.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
