How to interpret rotational, electronic, vibrational energy levels
In summary, rotational energy levels, electronic energy levels, and vibrational levels are different components of the total energy of a molecule or atom. The energy levels are quantized and can be represented by a graph of energy versus distance. Rotational energy levels are associated with the rotation of the entire molecule, vibrational energy levels with the vibration of the molecule, and electronic energy levels with the excitation of the electrons within the molecule. Vibrational levels are indexed for each electronic state, while rotational levels are only indexed for one vibrational state. The energy eigenvalues correspond to the discrete energies associated with each level. Overall, energy can be transferred to and between these different levels, contributing to the internal energy of the molecule.
fog37
1,568
108
Hello Forum,
I am confused about the concept of rotational energy levels, electronic energy levels, and vibrational levels. A graph of "Energy versus Distance" is usually presented and the various horizontal bars represent the energy levels, which are simply energy amounts.
The energy of a molecule/atom or system of atoms/molecules can be decomposed in 3 parts: rotational, vibrational and electronic energy (translational energy should also be included).
  1. Rotational energy is associated to the rotation of the entire structure of the molecule (nuclei+electrons).
  2. Vibrational energy is associated to the vibration of the entire molecule.
  3. Electronic energy refers to the excitation of the electrons inside the molecule only.
I read that the electronic ground state has, "contains", several vibrational energy levels. What does that exactly mean that an energy level contains other energy levels? Are there multiple vibrational energy levels inside the electronic ground state?
Some books explain that the vibrational levels are indexed for each electronic state while rotational levels are indexed only for one vibrational state...What does that really mean?
This is how I envision it: when a molecule absorbs energy from an external source its outer electron may remain in the ground state while the molecule is vibrating/rotating at the same time (i.e. the molecule is in an excited rotational/vibrational state) or the electrons may be in an excited state while the whole molecule is also rotating and/or vibrating...
  • The rotational energy levels represents the discrete (quantized) energies associated to the molecule or atom when the it is rotating, correct?
  • How about electronic energy levels? Do those electronic energies correspond to the energies associated with electrons when they are excited inside atoms or molecules?
  • The vibrational energy levels correspond to the energy that a molecule/atom has due to its vibrational motion (state), correct?
Am I on the right track?
Thanks,
Fog37
The energy that varies with distance is the potential energy function.
The energy "levels" are the energy eigenvalues.
The eigenvalues usually refer to the whole "thing" spoken of - unless the context (or other statements) indicate otherwise. So molecular levels are the energy eigenstates for the entire molecule.
It is difficult to say what a particular description means without the context. i.e. it would be unusual to think of electrons carrying any vibrational energy from the molecule. Perhaps someone is alluding to the Frank-Condon principle - where vibration and electron states can be closely linked?
Often books are a bit off-hand with their terminology, which can be confusing. This also makes comparing statements from different books tricky - you cannot always assume that the same words mean the same things. The trick is to look closely at the definitions and at the maths used.
I think your last three bullet points would be a common meaning when talking about molecules - the electronic, rotational, and vibrational, states would be contributions to the internal energy of the molecule. Energy may go to vibrating or spinning the molecule, or to exciting it's electrons. It may also go to translating the molecule - which would be external kinetic energy.
Related to How to interpret rotational, electronic, vibrational energy levels
1. What is rotational energy level and how is it interpreted?
Rotational energy levels refer to the different energy states that a molecule can have due to its rotation around an axis. This energy can be quantized and is typically measured in units of Joules. The interpretation of rotational energy levels involves understanding the different rotational states of a molecule and how they relate to its physical properties, such as its moment of inertia and rotational constant.
2. How are electronic energy levels determined and what do they represent?
Electronic energy levels are determined by the energy states of the electrons in a molecule. These levels are quantized and are measured in units of Joules. They represent the energy difference between the ground state (lowest energy level) and the excited states of a molecule. This energy difference is responsible for the absorption and emission of light by a molecule.
3. What is vibrational energy and how does it relate to molecular motion?
Vibrational energy refers to the quantized energy states associated with the vibrational motion of atoms within a molecule. This energy is typically measured in units of Joules and is related to the strength of the bonds between atoms in a molecule. As atoms vibrate, they can absorb or emit energy in the form of infrared radiation, which is important in understanding the structure and behavior of molecules.
4. How do rotational, electronic, and vibrational energy levels affect the overall energy of a molecule?
All three types of energy levels contribute to the overall energy of a molecule. The sum of the rotational, electronic, and vibrational energy levels gives the total energy of the molecule. These energy levels also interact with each other, leading to phenomena such as rotational-vibrational coupling and electronic-vibrational coupling.
5. How can energy level diagrams be used to interpret rotational, electronic, and vibrational energy levels?
Energy level diagrams are graphical representations of the different energy levels of a molecule. Each line on the diagram represents a specific energy level, and the spacing between the lines reflects the energy difference between them. By analyzing the energy level diagram, one can interpret the rotational, electronic, and vibrational energy levels of a molecule and gain insight into its physical and chemical properties.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
