I How to introduce dissipation to a spinning top
The discussion focuses on modifying the Lagrangian of an axisymmetric spinning top to account for dissipation at the pivot point. It emphasizes that the Lagrangian cannot be altered directly for dissipative systems, as they do not conform to Hamiltonian mechanics. Instead, general equations are suggested to describe the system's dynamics, incorporating a dissipation torque. The relationship between the generalized forces and the velocities is highlighted, indicating that dissipation results in non-positive work. Overall, the conversation centers on the complexities of incorporating dissipation into the Lagrangian framework.
etotheipi
A axisymmetric spinning top is pivoted at O. The components of the inertia tensor ##I_O## at the point ##O##, with respect to the principal axes, are denoted ##A##, ##A## and ##C##. It's Lagrangian is$$\mathcal{L}(\mathbf{q}, \dot{\mathbf{q}}) = \frac{1}{2} A\dot{\theta}^2 + \frac{1}{2}A(\dot{\phi} \sin{\theta})^2 + \frac{1}{2}C(\dot{\psi} + \dot{\phi} \cos{\theta})^2 - mgh\cos{\theta}$$How can the Lagrangian be modified to account for dissipation at the pivot? We can't use the Rayleigh function here, because that is for velocity-dependent dissipation. Are there some references?
You can not modify the Lagrangian in such a way because the system with dissipation is not a Hamiltonian system. Use general equations:
$$\frac{d}{dt}\frac{\partial L}{\partial \dot x^i}-\frac{\partial L}{\partial x^i}=Q_i(t,x,\dot x)$$
Dissipation means that ##Q_i\dot x^i\le 0##
If say you apply a dissipation torque ##\boldsymbol \tau## then
$$Q_i=\Big(\boldsymbol\tau,\frac{\partial\boldsymbol\omega}{\partial\dot x^i}\Big)$$
Likes vanhees71 and etotheipi
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
