Granger
- 165
- 7
Consider the following circuit of a counter with a clock signal of 84 kHz
As we can see the counter counts down. Show all the states and transitions of this counter and identify all the states using a binary representation. Calculate the frequency and the duty-cycle of the signal labeled 2
3. The Attempt at a Solution [/B]
So I didn't have any trouble with the first part of the problem, The states should be 1100 - 1011 - 1010 - 1001 - 1000 - 0111 and it repeats (so a total of 6 transitions).
Now the second part is the one that I'm not sure if I'm thinking correctly because this question never appeared to me.
My attempt to calculate the frequency. If I have 6 transitions all I have to do is to divide the clock frequency by the number of transitions (because If I had the period I would multiply it by the number of transitions). Anyway, I did it and obtained 14 kHz. Now the duty-cycle... I know what a duty-cycle. It's the percentage in the clock transition where the signal is high right? So it should be 1/6 = 17%...
I have no idea if I'm doing this correctly... I have a good feeling about the frequency but have no idea about the duty-cycle. Can someone give me some help? Thanks!
EDIT: The sequence is now correct
