I How to know whether it is +,- g and +,- y in the kinematic equations?
Determining the sign of the vertical coordinate (y) and gravity (g) can be confusing, as it depends on the chosen coordinate system. Gravity is always directed towards the Earth, meaning if +y aligns with gravity, g is 9.8 m/s², and if it opposes, g is -9.8 m/s². Textbooks may vary in how they present these signs, so reviewing specific chapters and worked examples is essential for clarity. Understanding vector algebra and calculus can also help mitigate confusion regarding these concepts. Mastery of these fundamentals is crucial for solving physics problems effectively.
bluesteels
TL;DR Summary
i was doing some problem and i have a hard time figuring out when will the y be positive and negative and same with the gravity idk if it -9.8 or 9.8
If +y has same direction with gravity, it is 9.8.
If +y has opposite direction with gravity, it is -9.8.
bluesteels said:
Summary:: i was doing some problem and i have a hard time figuring out when will the y be positive and negative and same with the gravity idk if it -9.8 or 9.8
There's no way to figure it out. It's your choice! Gravity is always directed towards the Earth - there is no choice about that.
You can also use ##z##, rather than ##y##, for the vertical coordinate, if you want.
It's a great idea to study vector algebra (and some calculus) in parallel to learning mechanics. Compared to the confusion some intro textbooks avoiding this utmost important mathematical tool for all of physics, it's a little effort, and it helps to avoid the typical confusion about signs discussed in this thread!
Most textbooks would already insert the minus sign in the latter case, so you would still replace g with 9.8.
Every rextbook does it differently. You would need to look at the relevant chapters and read some of the worked examples.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
