How to linearise this equation for experiment?
In summary, the equation for the moment of inertia of a mass hanging from a rotating platform can be solved for the acceleration using the approximation that I/mr^2 is much greater than 1.
Wimpalot
35
I have a rotating platform that spins as a mass attached to a wheel rotates the larger platform. The mass accelerates to the ground which spins the platform essentially. I am trying to calculate the moment of inertia of another mass which will be attached to the rotating platform. To do this I have a formula which I calculated:
I = (r^2 * m * (g - a))/a
Where I is the moment of inertia. r is the radius at which the string acts on the smaller "gear" wheel. m is the mass of the hanging object, g is the acceleration due to gravity and a is the actual acceleration of the object.
I have two questions:
1) Is this formula correct?
2) I need to linearise the equation so that I can perform linear regression by collecting data on the acceleration of the mass as it falls. How can I do this? All my attempts at making it linear have failed. I am allowed to use the approximation that I/mr^2 is much greater than 1 but I do not have to, it is optional
I used:
α=a/r
τ=Iα=rT
F = ma
Fg - T = ma
where T is the tension in the string and Fg is the force on the mass due to gravity
To get:
I = (r2 * m * (g - a))/a
The closest I can get is basically this:
I = (r2*m*g)/a - r2*m
But that is a hyperbola and I do not know how I can linearly regress using that
Let me understand the experiment first. You suspended different masses m, you measured the acceleration of the hanging mass a and you need to extract the moment of inertia I for a certain number of such measurements. Right?
Likes Wimpalot
Yes, so the mass falls and applies a torque to a gear which spins a larger platform. So we suspend different masses and measure the acceleration of them as they fall in order to calculate the moment of inertia
Right. So your dependent variable is the acceleration and the independent variable is the hanging mass. Your equation can be solved for the acceleration to yield
$$a=\frac{mR^2g}{I+mR^2}~\rightarrow~\frac{1}{a}=\frac{I+mR^2}{mR^2 g}$$
Hence
$$\frac{1}{a}=\frac{I}{mR^2g}+\frac{1}{g}$$
Can you see how to linearize this?
Edited to fix typos.
Likes Wimpalot
Hence
$$\frac{1}{a}=\frac{I}{mR^2}+\frac{1}{g}$$
Sorry, not quite. Can I also ask what happens to the g on the I/mR2 part at the end? But I do notice that that is the thing I can assume to be >> 1
Please note that I edited the equation I posted to add a "g" in the first denominator on the right side. The correct equation is
Suppose you let ##y=1/a## and ##x = 1/m## and you substitute in the above equation. What do you get?
Likes Wimpalot
Sorry, must have read before you fixed it.
Ohh, ok so I would end up with:
y = Ix/R2g + 1/g
Which is a linear equation with I/(R^2g) being the gradient of the line right?!
I also have a follow up question. This gets me the moment of inertia of the platform itself right? So how can I calculate the moment of Inertia of a block placed on the platform?
Calculate or measure? If "calculate", use the definition of moment of inertia; if "measure", repeat your measurements for different hanging masses with the block sitting on top of the platform. This will give you the combined platform + block moment of inertia from which you can subtract the platform value that you have already found. Ideally, you do both and compare your "calculated" value with your "measured" value.
Likes Wimpalot
Yes, I meant measure. So it is just as simple as subtraction? Excellent, thank you. So just do the experiment twice once with the block and once without and then subtract the platform only from the platform and box result. Thank you for all of your help. You have saved me a lot of stress tomorrow
Related to How to linearise this equation for experiment?
1. What is the purpose of linearizing an equation for an experiment?
The purpose of linearizing an equation for an experiment is to simplify the relationship between the variables and make it easier to analyze and interpret the data. By manipulating the equation to have a linear form, it becomes easier to identify patterns and trends in the data, and to make predictions based on the relationship between the variables.
2. How do I determine if an equation needs to be linearized for an experiment?
An equation should be linearized for an experiment if the relationship between the variables is not obvious or if the data collected does not fit a linear pattern. This can be determined by plotting the data on a graph and observing the shape of the curve. If the data appears to follow a linear trend, then the equation does not need to be linearized.
3. What are the steps for linearizing an equation for an experiment?
The steps for linearizing an equation for an experiment may vary depending on the specific equation, but generally involve manipulating the equation algebraically to transform it into a linear form. This may involve taking the logarithm or inverse of one or more variables, or performing other mathematical operations. Once the equation is in a linear form, the data can be plotted and analyzed more easily.
4. Can any equation be linearized for an experiment?
No, not all equations can be linearized for an experiment. Some equations are inherently non-linear and cannot be manipulated into a linear form. In these cases, alternative methods of analysis may be necessary, such as using curve fitting techniques or nonlinear regression.
5. Are there any limitations to linearizing an equation for an experiment?
Yes, there are limitations to linearizing an equation for an experiment. Linearization may simplify the relationship between variables, but it can also introduce errors and inaccuracies in the data. It is important to carefully consider the assumptions and limitations of linearization before applying it to an experiment, and to always validate the results using other methods of analysis.
9K
