How to Make 24 with 21, 20, 22, and 6 Using Basic Operations?
  • MHB
  • Thread starter Monoxdifly
In summary, you can make 24 with the numbers 21, 20, 22, and 6 by adding 21 and 22, subtracting 20, and subtracting 6. It is also possible to use a combination of addition, subtraction, multiplication, and division to make 24. However, using only multiplication or division will not yield the desired result.
Monoxdifly
MHB
284
How to make 24 with the numbers 21, 20, 22, and 6 each once using only addition, subtraction, multiplication, and division? If only the number 22 was replaced with 23 I could do that, but how can I do it with the given numbers?
- - - Updated - - -
Never mind, I get it. It's 21 + 6 : (22 - 20). Can't believe I am this stupid.
Mathematics news on Phys.org
How about:
\(\displaystyle 21+\frac{6}{22-20}=24\)
FAQ: How to Make 24 with 21, 20, 22, and 6 Using Basic Operations?
How can I make 24 with 21, 20, 22, and 6?
To make 24 with these numbers, you can add 21 and 22 to get 43, then subtract 20 to get 23, and finally subtract 6 to get the desired result of 24.
Is it possible to make 24 using only addition and subtraction with 21, 20, 22, and 6?
Yes, it is possible. As mentioned in the previous answer, you can add 21 and 22 to get 43, then subtract 20 to get 23, and finally subtract 6 to get 24.
Can I use multiplication or division to make 24 with 21, 20, 22, and 6?
No, you cannot make 24 using only multiplication or division with these numbers. However, you can use a combination of addition and subtraction as described in the first answer.
Are there any other ways to make 24 with 21, 20, 22, and 6?
Yes, there are multiple ways to make 24 with these numbers. Another way would be to multiply 20 and 6 to get 120, then divide by 21 to get approximately 5.71, and finally add 22 to get 27.71, which can be rounded down to 24.
Can I make 24 with these numbers using any mathematical operations?
Yes, you can make 24 using a combination of mathematical operations. For example, you can raise 6 to the power of 2 to get 36, then add 20 to get 56, divide by 22 to get approximately 2.55, and finally multiply by 21 to get approximately 53.33, which can be rounded up to 24.
