How to make successful helmet from scratch
  • Thread starter Madmace10
  • Tags
    scratch
In summary, a helmet must be able to compress linearly under deceleration, be strong and stiff enough to resist a sharp object, and have a soft lining to avoid localised crushing.
Madmace10
< Mentor Note -- thread moved to HH from the technical physics forums, so no HH Template is shown >
We have to make a helmet in engineering class that will survive a bludgeoning from the teacher with a hockey stick. I am not sure what the best materials to use would be or the best way to make it. Additional info is that we are trying to make a helmet for rugby that will be safe.
Any constraints to the design? You could go Dark Helmet, that would certainly be safe (but obviously rather impractical).
One important aspect to overview is the impulse. You should try to have a dampening in the helmet so the force is spread out over time. From there you could look at different foams or other materials with low weight.
only restraints are the outside has to be paper machete (to add decoration) the helmet has to protect a watermelon
The thing to optimize in the helmet will be the deceleration of the head. So, to some degree you will be bound by very basic physics. E.g. if the helmet is of thickness d, the smallest deceleration from speed v will be a continuous declaration across that distance d, the deceleration given by
a = v^2/(2s)
So, on the one hand you're looking for a material that will compress linearly under such deceleration, but at the same time you're also looking for a material that will distribute a sharp impact across the head area (so you don't get impaled by something). Those two are somewhat opposed to each other.
There are three things a helmet needs to do.
As others have noted, you want the impulse spread as evenly as possible over time. An elastIc material won't do that well because the resistance increases linearly with compression. A material that yields plastically is better, offering a more or less constant resistance as it collapses. The tricky part is that you need to get the resistive force right. Too high, and too much force will be transferred to the head, too low and it will collapse completely before enough of the blow has been absorbed. So the ideal is a resistance just a bit less than the natural strength of what you are trying to protect - in this case, the tissues that hold the brain together.
As also noted, you need to be able to cope with a blow from a sharp object. That implies a strong and stiff outer shell.
The third is to spread the blow evenly over an area of the skull so as to avoid localised crushing, so a softer lining (but this is the least important of the three).
As regards onslaught by the teacher, an Apprehended Violence Order should also be effective. Consult your lawyer.
Likes billy_joule
Related to How to make successful helmet from scratch
1. How do I choose the right materials for a helmet?
The first step in making a successful helmet is choosing the right materials. Look for lightweight and strong materials such as polycarbonate, carbon fiber, or Kevlar. Consider the type of impact protection you need and select materials accordingly.
2. What is the best design for a helmet?
The best design for a helmet depends on its intended use. For example, a bicycle helmet should have vents for airflow, while a motorcycle helmet should have a streamlined shape to reduce drag. Research existing helmet designs and consult with experts to determine the most suitable design for your helmet.
3. How do I ensure a proper fit for a helmet?
A proper fit is crucial for a successful helmet. Measure the circumference of the head and choose a helmet size accordingly. Make sure the helmet sits snugly on the head and does not move around. Adjust the straps and padding for a comfortable and secure fit.
4. Do I need to consider any safety standards when making a helmet?
Yes, it is important to consider safety standards when making a helmet. Look for safety certifications such as DOT, Snell, or ECE to ensure that your helmet meets the necessary safety requirements. These standards test for impact resistance, penetration, and retention systems.
5. How can I test the effectiveness of a homemade helmet?
It is important to test the effectiveness of a homemade helmet before using it. You can conduct impact tests by dropping the helmet from different heights onto a hard surface and then inspecting for cracks or damage. You can also test the helmet on a dummy or in a simulated crash scenario to evaluate its impact protection.
