zzyjetty521
- 1
How to make your own iPhone Ringtone and transfer it to your iPhone directly?
rootX said:Don't you forced to download through itunes/something only?
Sorry! said:OH is he asking how to transfer a song or something from a computer to an iPhone? That's easy enough just look on the web... you can use many methods e-mail, usb, bluetooth, media cards, media messaging... just download from a website... it's endless lol.
rootX said:He is asking:
1) How to make your own iPhone Ringtone
- I believe mpeg/avi files are not compatible with iphone so you use some program to convert to the iPhone format files (or iTunes)
2) transfer it to your iPhone directly?
- Use that song/something as iPhone Ringtone
This is one of other ways ...
http://www.ehow.com/how_2160460_custom-iphone-ringtones-free.html
zzyjetty521 said:How to make your own iPhone Ringtone and transfer it to your iPhone directly?
kpachla said:New user here, thought I'd help out as my first post!
It's pretty easy, you need to do the following steps:
1) Pick a song
2) Listen to the song to find out what portion of the song you want to use. Watch the time and write down the start / stop time. Try to make it under 30 seconds or so.
3) Right click on the song and hit "info"
4) Go to the "Options" tab
5) near the bottom there is "Start Time" and "Stop Time" --> put these numbers that you wrote down into here (don't worry, it's not permanent)
6) After you've got the numbers in, right click on the song and hit "Make AAC Version"
7) Drag the new version to the desktop. Remove the new version from iTunes.
8) Change the file extention from .m4a to .m4r
9) Drag it back in. iTunes recognizes it as a ringtone now!
Hope this helps!
Saladsamurai said:You know I was originally going to reply with a question: Did you seriously create an account at PF with soul purpose of asking a question that could just as easily have been answered by typing the exact same question into Google? I can't decide if that is laziness or not.
But I am wayyy to busy to making 'Whoomp there it is' my ringtone to do that.
Thanks kpachla!
To convert a song or audio file into an iPhone ringtone, you will need to use iTunes on a computer. Open iTunes and select the song you want to use as a ringtone. Right-click on the song and select "Get Info." Go to the "Options" tab and set the start and stop times for the ringtone (maximum of 30 seconds). Click "OK" and then right-click on the song again and select "Create AAC Version." This will create a shortened version of the song. Right-click on the new version and select "Show in Finder" (on a Mac) or "Show in Windows Explorer" (on a PC). Change the file extension from .m4a to .m4r. Drag and drop the .m4r file into iTunes and it will appear under the "Tones" section. You can now sync the ringtone to your iPhone via iTunes.
Yes, you can make a ringtone from a song that you purchased from the iTunes Store. However, you will need to make sure that the song is DRM-free. To check this, right-click on the song in iTunes and select "Get Info." Go to the "File" tab and look for the "Kind" field. If it says "Purchased AAC audio file," then the song is DRM-protected and cannot be used as a ringtone. If it says "AAC audio file," then the song is DRM-free and can be converted into a ringtone following the steps outlined in the first question.
There are a few third-party apps that allow you to create and add custom ringtones to your iPhone without using iTunes. Some popular options include GarageBand, Ringtone Designer, and Ringtones for iPhone. These apps typically have a user-friendly interface and allow you to create ringtones from songs already on your iPhone, or from your own audio files.
Yes, you can set a custom ringtone for specific contacts on your iPhone. To do this, go to the Contacts app and select the contact you want to set a custom ringtone for. Tap "Edit" in the top right corner and then scroll down to the "Ringtone" section. Tap on the current ringtone and select the custom ringtone you want to use for this contact. Tap "Done" to save the changes.
Yes, there is a limit to the number of custom ringtones you can have on your iPhone. The maximum number of ringtones you can have is 500, including both stock and custom ringtones. If you reach this limit, you will need to delete some ringtones before you can add more. You can delete ringtones by going to Settings > Sounds & Haptics > Ringtone and swiping left on the ringtone you want to delete.
