How to Maximize the Product ab Given Specific Square Root Conditions?
  • MHB
  • Thread starter anemone
In summary, the purpose of maximizing ab with sqrt equations is to find the maximum value of a product (ab) when one or both of the factors (a and b) are square root expressions. This can be solved using various methods such as graphing, substitution, or differentiation. Common applications include economics, engineering, and physics, and tips for solving these problems include understanding the variables and constants, using algebraic principles, and checking answers. "POTW #295 Jan 2, 2018" in the title refers to a specific problem or competition related to this topic.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let $a,\,b$ be non-negative numbers with \(\displaystyle \sqrt{1-\frac{a^2}{4}}+\sqrt{1-\frac{b^2}{16}}=\frac{3}{2}\).
Find the maximum value of $ab$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution: (Smile)
1. castor28
2. kaliprasad
Solution from castor28:
Let us write $x=\dfrac{a^2}{4}$, $y=\dfrac{b^2}{16}$. Maximizing $xy$ is equivalent to maximizing $ab$, but the equations are simpler.
The domain of interest is an arc of parabola between the points $\left(0,\dfrac34\right)$ and $\left(\dfrac34,0\right)$; in particular, we have:
$$ 0 \le x,y\le\frac34$$
The problem can be restated as: maximize $xy$ subject to the condition $\sqrt{1-x} + \sqrt{1-y} = \dfrac32$.
We define the Lagrange function:
$$L = xy +\lambda\left(\sqrt{1-x} + \sqrt{1-y} - \dfrac32\right)$$
and compute the partial derivatives:
$$\begin{align*}
\frac{\partial L}{\partial x} &= y - \frac{\lambda}{2\sqrt{1-x}} = 0\\
\frac{\partial L}{\partial y} &= x - \frac{\lambda}{2\sqrt{1-y}} = 0
\end{align*}$$
Eliminating $\lambda$, we get:
$$\begin{align*}
&\lambda = 2y\sqrt{1-x}= 2x\sqrt{1-y}\\
&y^2(1-x) = x^2(1-y)\\
&(x-y)(x+y-xy) = 0
\end{align*}$$
Because $0\le x,y<1$, we have $(x+y-xy)> 0$ (unless $x=y=0$, which does not satisfy the equation). This shows that there is only one extremum inside the domain. As we have $xy=0$ on the endpoints and $xy>0$ inside, this is indeed a maximum.
Note that it is a priori obvious that there is an extremum for $x=y$, because of the symmetry of the expression; however, we had to prove that this is the only extremum.
With $x=y$, the equation becomes:
$$2\sqrt{1-x}=\dfrac32$$
giving $x=y=\dfrac{7}{16}$, $a = \dfrac{\sqrt7}{2}$, $b=\sqrt7$, and $ab=\dfrac72$.
Alternative solution:
By using trigonometric substitution, we let
$\dfrac{a}{2}=\sin x$ and $\dfrac{b}{4}=\sin y$
Therefore the condition becomes $\cos x+\cos y=\dfrac{3}{2}$ and we need to maximize $\sin x \sin y$.
Apply the AM-GM inequality we get
$\begin{align*}\sin x \sin y &\le \dfrac{\sin^2 x+\sin^2 y+2\sin x \sin y}{4}\\&=\dfrac{2\sin x \sin y+2-\left(\dfrac{9}{4}-2\cos x \cos y \right)}{4}\\&=\dfrac{2\cos (x-y)-\dfrac{1}{4}}{4}\\& \le \dfrac{\dfrac{7}{4}}{4}\\&=\dfrac{7}{16}\end{align*}$
Hence, the maximum of $ab$ is $\dfrac{7}{2}$.
FAQ: How to Maximize the Product ab Given Specific Square Root Conditions?
What is the purpose of maximizing ab with sqrt equations?
The purpose of maximizing ab with sqrt equations is to find the maximum value of a product (ab) when one or both of the factors (a and b) are square root expressions. This allows you to find the optimal values for a and b that will result in the largest possible product.
How do you solve for the maximum value of ab with sqrt equations?
To solve for the maximum value of ab with sqrt equations, you can use a variety of methods such as graphing, substitution, or differentiation. These methods will help you find the values of a and b that will give the largest possible product of ab.
What are some common applications of maximizing ab with sqrt equations?
Maximizing ab with sqrt equations is commonly used in fields such as economics, engineering, and physics. It can be used to optimize profits, design efficient structures, or determine the maximum possible force in a system.
What are some tips for solving problems involving maximizing ab with sqrt equations?
Some tips for solving problems involving maximizing ab with sqrt equations include identifying the variables and constants in the equation, using basic algebraic principles to manipulate the equation, and understanding the properties of square root expressions. It is also helpful to check your answer by graphing or using a calculator.
Can you explain the significance of the "POTW #295 Jan 2, 2018" in the title?
"POTW #295 Jan 2, 2018" refers to the "Problem of the Week" for the week of January 2, 2018. This is a specific problem or challenge that was given to students or scientists to solve using their knowledge of maximizing ab with sqrt equations. It may also refer to a specific competition or event related to this topic that took place on that date.
