How to measure CMB anisotropies *In Practice*
In summary, the procedure for measuring the power spectrum of the CMB is to take the variance of the wave amplitudes at a given wavelength.
astrolollo
24
Hi everyone
Given the definition of ##C_{l}##, ##C_{l}=\frac{1}{2l+1} \sum a_{l,m} Y_{l,m}##, I was wondering how it is possible to measure the ##C_{l}##s in practice. How does one compute this quantity, having a map of the temperature anisotropies of the CMB?
Space news on Phys.org
The temperature of the CMB is a function on a sphere. As such, it can be expanded in terms of the spherical harmonics ##Y_\ell^m##. The way of computing the expansion coefficients is the same as you would do in any expansion in terms of the eigenfunctions of a Sturm-Liouville operator - you simply take the inner product of the function you wish to expand (in this case the CMB temperature function) and the orthogonal basis functions (in this case the spherical harmonics), this corresponds to an integral over the domain of the functions (in this case a sphere).
The procedure is exactly equivalent to finding the expansion coefficients in a Fourier series.
astrolollo said:
Hi everyone
To expand a little bit upon what Orodruin said, the first step is to take a spherical harmonic transform:
[tex]a_{\ell m} = \int Y_{\ell m}(\theta, \phi) T(\theta, \phi) sin(\theta) d\theta d\phi[/tex]
Here ##T(\theta, \phi)## is the CMB temperature in different directions on the sky. There are various mathematical tricks used to make this integral efficient to compute on a computer (a common library used for this is Healpix).
The power spectrum is then the variance of the amplitude at a given ##\ell##. Each ##Y_{\ell m}## can be thought of as a wave on the surface of a sphere, with the wavelength given by ##\ell## and the direction given by ##m##. Each ##a_{\ell m}##, then, is the amplitude of the wave with wavelength ##\ell## and direction ##m##. To get the power spectrum, we take the variance of the wave amplitudes of each direction at a given wavelength:
[tex]C_\ell = {1 \over 2\ell + 1} |a_{\ell m}|^2[/tex]
Here the factor of ##a/(2\ell + 1)## comes from the fact that ##\ell## and ##m## are integers, with ##\ell \ge 0## and ##-\ell \le m \le \ell##. For example, if ##\ell = 2##, then ##m = {-2, -1, 0, 1, 2}##.
There are lots of other complications that come in from the fact that there is stuff between us and the CMB, so that we don't have a perfectly-clean full-sky map. Various techniques are used to extract the CMB signal, but I think I'll stop here for now.
Does this answer your question? Did you have any other concerns?
Related to How to measure CMB anisotropies *In Practice*
1. What equipment is needed to measure CMB anisotropies?
The main equipment needed to measure CMB anisotropies includes a radio telescope, a low-noise detector, and a data acquisition system. The radio telescope is used to detect the faint signal from the CMB, while the low-noise detector is used to measure the fluctuations in the CMB. The data acquisition system is responsible for recording and analyzing the data collected by the telescope and detector.
2. How is the CMB anisotropy signal extracted from the data?
The CMB signal is extracted from the data using a process called foreground subtraction. This involves removing any contaminating signals from sources such as the galaxy, dust, and other astrophysical sources. Once these signals are removed, the remaining signal is assumed to be from the CMB anisotropies.
3. How is the CMB anisotropy measured in terms of temperature fluctuations?
The CMB anisotropy is measured in terms of temperature fluctuations using a unit called the microkelvin (µK). This unit represents very small variations in temperature, which can range from a few microkelvins to tens of microkelvins. These fluctuations are the result of variations in the density of matter in the early universe, which are imprinted on the CMB as it travels through space.
4. What is the significance of measuring CMB anisotropies?
Measuring CMB anisotropies is significant because it provides us with valuable information about the early universe, specifically the conditions and processes that led to the formation of structures such as galaxies and galaxy clusters. It also allows us to test theories about the origin and evolution of the universe, such as the inflationary model.
5. How does the measurement of CMB anisotropies contribute to our understanding of dark matter and dark energy?
The measurement of CMB anisotropies is important in studying dark matter and dark energy because it provides us with a map of the distribution of matter in the universe. This map can be used to study the effects of dark matter and dark energy on the evolution of the universe. It can also help us to better constrain the properties of these mysterious components of the universe.
  • Cosmology
