How to measure emissivity of hot (~1000 centigrade) objects
In summary, the conversation discusses the need to measure the emissivity of hot ceramic materials in the wavelength range of 1-10 micrometers. The traditional method using an FTIR spectrometer with a gold coated integrating sphere is not feasible for very hot objects. The person suggests using an IR thermometer for high temperatures, with a Google search resulting in a potential solution from Omega that claims to measure up to 1800C.
M_1
31
I want to measure the emissivity (or more correctly the absorbtivity) in the wavelength range 1 - 10 micrometer of very hot (~1000 degrees Celcius) ceramic materials. At room temperature this is typically done using an FTIR spectrometer with a gold coated integrating sphere. But for very hot objects the spectrometer would burn! Any ideas of how such emissivity measurement can be performed in a practical, yet accurate, way? I have access to varius furnaces.
Related to How to measure emissivity of hot (~1000 centigrade) objects
1. What is emissivity and why is it important to measure it for hot objects?
Emissivity is a measure of the efficiency of an object to emit thermal radiation. It is important to measure the emissivity of hot objects because it affects their ability to absorb and emit heat, which is crucial in many industrial, engineering, and scientific applications.
2. How is emissivity measured for hot objects?
Emissivity can be measured using various techniques such as infrared thermography, spectrophotometry, and pyrometry. These methods involve measuring the thermal radiation emitted by the object and comparing it to a known reference source.
3. Can the emissivity of an object change at different temperatures?
Yes, the emissivity of an object can change at different temperatures. This is because emissivity is affected by several factors such as surface roughness, chemical composition, and temperature. It is important to consider these factors when measuring emissivity at high temperatures.
4. What are some common sources of error when measuring emissivity of hot objects?
One common source of error is the presence of surface contaminants or oxidation layers on the object, which can affect its emissivity. Another source of error is the use of improper measurement techniques or equipment. It is important to carefully prepare the object and use appropriate methods to minimize errors.
5. How can emissivity measurements of hot objects be used in practical applications?
Emissivity measurements of hot objects are used in various industries and fields such as materials science, metallurgy, and thermal engineering. They can be used to optimize processes, improve energy efficiency, and ensure quality control in manufacturing. Emissivity measurements can also be used to study and understand the thermal properties of different materials at high temperatures.
  • Thermodynamics
30K
  • Materials and Chemical Engineering
9K
