How to mesure very small change in distance?
  • Thread starter memeplus
  • Tags
    Change
In summary: Would be useful for checking the accuracy of a machine tool.In summary, a small object that has moved a very small distance can be measured by using a laser projected onto the end of the beam which is reflected into a 1d CCD, which can be measured very accurately.
memeplus
if a object changed position by a very small distance, how to mesure it?
Define "small". 0.1 cm may be small to you, but in terms of optical measurement, that's the size of our galaxy. Or the Earth may be large to you, but in terms of galactic scale, it is minuscule.
Zz.
reply
i mean around 10mm, what are some of the methods, such as electrical or optical experiments or any other method that can measure it, excluding using the dial calibrator?
Can you be a little more specific? What kind of objects? What moves them?
Are you a meter maid for Matchbox cars? You could use a tiny piece of chalk and a set of calipers.
let's say the end of a thin beam moved several millimeters under pressure, how to measure that? and generally what are some of the methods to measure very small displacement?
10 mm is LARGE. A micrometer caliper would measure something like that easily. You also didn't mention what kind of accuracy you want to measure such things.
Zz.
sorry for all the confusion, it should be mesured without a caliper, that is, by indirect methods.0.1mm accuracy would be ok.
You can already see why, if you are vague and give a rather incomplete description of the task in the very beginning, you'll get responses like this and could possibly even annoy well-intentioned people who are trying to help. It is why we always ask for the most complete description of the problem.
As of now, I think I've lost interest in this one, so I'll let others take over.
Zz.
What exactly do you want to measure, how accurately do you want to measure it, what are the constraints on what you can use to measure it.
Sounds like this is a small scale beam bending experiment.
The best device is probably a laser projected onto the end of the beam which is reflected into a 1d CCD, as the beam bends to position of the spot along the CCD changes. This can be measured very accurately.
I can't rememebr the name of the company that makes them - someone here might be able to help.
Alternately a phase type laser distance meter 'Leica Disto' would give you probably 1mm accuracy.
Depending on the range required, laser devices can measure sub micron distances. A web search for laser measurment will produce quite a few hits.
We used a HP laser interferometer for our astronomical interferometer, it could track the telescope separation to 1/512 wavelength at distances of 100m - but I suspect it is out of our friends price range!
The devices I was thinking of are these, http://www.me-us.com/laser-sensor/
(no recomendation for this company - first thing google turned up)
It uses a laser at an angle which is reflected back onto a 1d CCD, the distance along the CCD is easy to measure with high resolution which gives a very fine measurement of the distance. Great for close range measurements of reasonably reflective surfaces.
Hey, cool devices, mgb_phys. Thanks for the link. That's probably just what the OP is looking for. And yeah, I forgot about the price tag of the HP instruments. Even the cheapest one that I think I ever saw was still several $k.
If the OP's beam is bending through a significant angle he might have to put in a correction for the tilt of the mirror but generally these are great for short range non-contact measurements on eg. machine tools.
Lower resolution than inteferometers but much much cheaper.
Related to How to mesure very small change in distance?
1. How can I measure very small changes in distance?
One way to measure small changes in distance is by using a laser interferometer. This instrument uses a laser beam to measure the interference pattern between two beams that are reflected off of a surface. By analyzing the changes in this pattern, the instrument can accurately measure small changes in distance.
2. What is the resolution of a laser interferometer?
The resolution of a laser interferometer depends on the wavelength of the laser used and the precision of the instrument. Generally, a laser interferometer can measure changes in distance as small as a few nanometers.
3. Can I use a ruler or caliper to measure small changes in distance?
No, traditional measuring tools like rulers and calipers are not suitable for measuring very small changes in distance. These tools are not precise enough and may not be able to measure changes smaller than a millimeter.
4. Are there other methods for measuring small changes in distance?
Yes, there are other methods for measuring small changes in distance, such as using a capacitance sensor or an eddy current sensor. These methods use electrical signals to measure changes in distance and can achieve high levels of precision.
5. Is it possible to measure very small changes in distance without specialized equipment?
In most cases, it is not possible to accurately measure very small changes in distance without specialized equipment. However, you can use a microscope or magnifying glass to estimate changes in distance to a certain degree of accuracy.
  • Other Physics Topics
  • Quantum Interpretations and Foundations
