How to minimize the cost function
In summary: OK, the author asks about the minimum information that includes both sales and inventories in order to minimize this function.In summary, the cost function can be minimized with the help of the assumption that includes both sales and inventories.
Kinetica
88
The cost function:
E(Cost)=E(F-LS)3
F is for Finished goods
L is for Lambda
S is for Sales
After expanding the function, what assumption minimized this function with respect to F?
F3-3F2LS+3F(LS)2-(LS)3
I know that I need to identify the terms that include both sales and inventories. The sales terms are the information needed for minimization.
Any ideas?
Thanks!
Sounds like a standard multivariate calculus minimization problem. I'm assuming that the cost is a function of both F and S. To find the min w.r.t F, take the partial derivative w.r.t F, set it equal to zero. Take the partial w.r.t S, set it equal to zero. Solve the simultaneous system to find the critical point(s). Then, classify these critical points as maxima, minima, or saddle points by taking the second derivative, plug in the critical points, note the sign of the second derivative w.r.t F both times. Then, calculate the determinant of the Hessian matrix. Using both the sign of the second derivative and determinant of the Hessian in order to classify each critical point. The details can be found in any calculus textbook.
That's very helpful!
Thank you!
Kinetica said:
The cost function:
E(Cost)=E(F-LS)3
L is for Lambda
S is for Sales
Any ideas?
Thanks!
What does 'E' stand for? Typically in such problems, E is the expectation operator, and quantities like S are random (because we don't really control demand). Also, what is Lambda?
My guess is that S (and maybe Lambda) are either given data or given random variables with known probability distributions. That would leave F as the only 'variable' in the problem (and it is non-random), so you would just minimize the function [itex] {\cal F}(F) = F^3 - 3 E(LS) F^2 + 3 E[(LS)^2] F - E[(LS)^3], [/itex] as a univariate function of F. However, I could be wrong, depending on what the symbols in you problem actually mean. To minimize [itex]\cal{F}[/itex] you look where the derivative equals zero, and also worry about the possibility of an end-point optimum if there are lower and upper bounds on F; the derivative need not be zero at end-points.
RGV
I took the second derivative of the function with respect to F (as asked in the problem), which is
6F-6LS
I know that the cost function is convex meaning that 6F-6LS is supposed to be positive.
So
6F-6LS>0 or
6(F-LS)>0 or
F-LS>0 or
F>LS, which means that the amount of finished goods should be greater than the amount of sales multiplied by Lambda.
I guess, this is the final answer.
6F-6LS
So
6F-6LS>0 or
6(F-LS)>0 or
F-LS>0 or
"I know that the cost function is convex meaning that 6F-6LS is supposed to be positive."
No: it is supposed to be >= 0, not necessarily positive.
"F>LS, which means that the amount of finished goods should be greater than the amount of sales multiplied by Lambda."
No: you should have F >= LS. It is convex in the region F >= LS and _strictly convex_ in the sub-region F > LS. It is important (sometimes) to be able to distinguish convexity from strict convexity. Certainly, in optimization it is crucial to distinguish between ">" and ">=".
RGV
Related to How to minimize the cost function
1. How does minimizing the cost function impact overall cost?
Minimizing the cost function is a method used in optimization to find the most efficient way to reduce costs. By minimizing the cost function, companies can identify areas where costs can be reduced, leading to overall cost savings.
2. What strategies can be used to minimize the cost function?
There are many strategies that can be used to minimize the cost function, such as reducing waste, increasing efficiency, negotiating better prices with suppliers, and implementing cost-saving technologies.
3. What are the benefits of minimizing the cost function?
The main benefit of minimizing the cost function is cost savings. By reducing costs, companies can increase their profits and become more competitive in the market. Additionally, minimizing the cost function can also lead to improved efficiency, quality, and customer satisfaction.
4. What are the potential challenges of minimizing the cost function?
One of the main challenges of minimizing the cost function is finding the right balance between cost reduction and maintaining quality. Cutting costs too much can lead to lower quality products or services, which can negatively impact customer satisfaction. Additionally, there may be initial costs associated with implementing cost-saving strategies, such as investing in new technology or training employees.
5. How can data analysis help in minimizing the cost function?
Data analysis can play a crucial role in minimizing the cost function. By analyzing data on costs, companies can identify patterns and areas where costs can be reduced. This can help companies make data-driven decisions and prioritize cost-saving strategies that will have the most significant impact on their overall cost reduction efforts.
10K
