How to obtain other inverse metrics than that of Schwarzschild?
In summary, the conversation discusses the possibility of a new metric being derived from the Schwarzschild solution, with a specific form that is different from the traditional Schwarzschild metric. However, it is mentioned that this new metric is not a vacuum spacetime and would require knowledge of the stress-energy tensor to be derived. The conversation also touches on the need to specify starting assumptions, such as spherical symmetry and time invariance, in order to find a solution.
  • #38
PeterDonis said:
Where does he write the things you quoted?
He wrote this in private message with me.
Also he writes" In other words, if you raise the indices of the metric, you must lower the indices of the coordinates. The summation indices must always balance upstairs and downstairs. Many introductory relativity textbooks skip over this and “simplify” the expressions, e.g., by not distinguishing between covariant and contravariant indices; by doing so, they do a disservice to readers/students."
  • #39
I don't know any serious textbook, which does not carefully use co- (lower) and contravariant (upper) indices. The only exception is that in Euclidean field theory in special relativity or in old-fashioned books, where they use the "##\mathrm{i} c t## convention" for real-time physics, where you have ##\delta_{\mu \nu}## instead of ##\eta_{\mu \nu}## anyway, and you don't need to distinguish between upper and lower indices (although using the Cartesian Ricci calculus the mathematical distinction between vector components/basis vectors and dual-vector components/co-basis vectors is lost).
  • #40
That's not a valid reference for a PF discussion.
This doesn't make sense. The coordinates themselves don't have indices.
The ##dx^\mu## that appear in the line element ##ds^2## are coordinate differentials. It doesn't really make sense to lower the indices on those either.
The metric can also be used to give the inner product of two vectors. In that case it makes sense to lower the indices on the vectors (to get the corresponding covectors), as long as you also raise the indices on the metric (to get the inverse metric). The inner product remains invariant under these operations. But in the OP of this thread you didn't write the inner product of vectors, you wrote line elements. Those have coordinate differentials in them, not vectors.
Likes vanhees71 and Bishal Banjara
  • #41
If I want to write the line element with all its metric coefficients just inverse than Schwarzschild line element, then is he right? I mean $$g_{\mu\nu} dx^\mu dx^\nu=g^{\mu\nu} dx_\mu dx_\nu$$.
  • #42
Formally yes, but it doesn't make too much sense.
  • #43
As @vanhees71 says, formally this is correct, but what do ##dx_\mu## and ##dx_\nu## even mean? As I said before, those are coordinate differentials, and it doesn't make sense to lower indexes on those.
  • #44
It's simply defined by
$$\mathrm{d} x_{\mu} =g_{\mu \nu} \mathrm{d} x^{\nu}.$$
The ##\mathrm{d} x^{\mu}## are vector components with respect to the holonomous basis ##\partial_{\mu}##, and the ##\mathrm{d} x_{\mu}## are co-vector components with respect to the corresponding dual basis, which is ##\mathrm{d} x^{\mu}## itself.
  • #45
I understand how it's defined mathematically. But you yourself said it doesn't make too much sense. Are you now saying it does?
Likes vanhees71
  • #46
Of course, you know this, and I still don't see, why I should rewrite it with contravariant components. Some quantities are "naturally described" by contravariant components, as the ##\mathrm{d} x^{\mu}##, others by covariant components. E.g., the metric is "naturally described" by covariant components ##g_{\mu \nu}##, because after all it maps to vectors bilinearly to a scalar and as such is a 2nd-rank tensor (field).
  • #47
Neither do I. I'm not the one asking about that, the OP is.
Likes vanhees71
  • #48
As we've said, you can do this mathematically but it doesn't make much sense. However, as we have already pointed out, this is not what you did in the OP. The alternate metric you wrote in the OP is not what you get if you take the inverse metric of the standard Schwarzschild metric and pretend you can write it as a line element.
Likes vanhees71
  • #49
He writes.....In terms of geometry, $dx^μ$ is an infinitesimal vector in the $x^μ$ direction. I think of $dx^μ$ as a corresponding line, surface, volume, etc. element (depending on the dimensionality of the manifold) to which $dx^μ$ is normal. The inner product, $dx_μdx^μ=g_μνdx^νdx^μ=ds^2$ is just the invariant line element. (Indeed, that is the formal definition of a covector like $dx_μ$: a covector is what maps a vector into a scalar.) This should tell you that $dx^μ$ and $dx_μ$ carry the same information in different form, just as I can specify a direction and a magnitude in 3D space using either an arrow (a vector) or a surface element of a given size facing a given direction. Two different representations, but the same information content, same degrees of freedom.
  • #50
He writes
Unless you can give a published, valid source for these quotes, they are out of bounds here.
  • #51
@Bishal Banjara I am closing this thread since your original question has been addressed.
Likes Bishal Banjara
