How to obtain the spectrum for a given atom or simple molecule?
In summary, spectral calculations using quantum mechanics can provide accurate predictions for the energy levels and spectra of atoms and molecules. However, the complexity of the system being studied and the limitations of computing power and techniques will determine the accuracy of these predictions. In some cases, it may be more practical to rely on experimental spectroscopic data.
jordi
197
The Bohr atom gave the answer to the spectrum of the hydrogen atom.
But the spectra of stars contains many absorption (and sometimes emission) lines, corresponding to most atoms (up to iron, I believe).
And atmospheric absorption is also due to absorption of some molecules, such as water, carbon dioxide and, I assume, some nitrogen molecule.
My question is: where can I find information to find methods (which I assume are numerical, say Hartree-Fock or extensions thereof) that are able to determine/predict/posdict the absorptions of a given atom and molecule, including electronic / vibration / rotation / ... modes?
DrClaude said:
What is needed is computational chemistry software, see
https://en.wikipedia.org/wiki/List_of_quantum_chemistry_and_solid-state_physics_software
Note that getting good numbers can be quite involved, especially for more complicated systems.
It is often best to rely on experimental spectroscopic data.
Thank you. Is there a book on both the underlying methods, and the practical usage of this software? I have heard about CP2K and Gaussian.
I don't know if there is a book that covers both. This software is mostly targeted at researchers, so a certain base knowledge is assumed. Also, many different approaches can be used, from semi-empirical methods to density functional theory, so I don't think you can get it all in one source.
For a very basic introduction to the subject, there is a chapter on computational chemistry in Atkins and Friedman's Molecular Quantum Mechanics. Likewise, a basic introduction can be found in Schrier, Introduction to Computational Physical Chemistry. A more complete description of Hartree-Fock methods can be found in McWeeny, Methods of Molecular Quantum Mechanics (it is graduate level).
Thinking about it, there would be one book that covers method and software, which is MOTECC. You might be able to find it in a university library, but I don't know if it is possible to get the software that is described in there.
https://books.google.com/books?id=v...YsKHV_-DfwQ6AEwA3oECAkQAQ#v=onepage&q&f=false
Likes Charles Link, Cryo, Astronuc and 2 others
As has been mentioned, there is no one book that covers everything. In fact, there is no one method that can numerically calculate every single transition for every single atom and molecules. It is why things like DFT often come up in many of such computation, etc.
BTW, most of the spectra (emission and absorption) that are currently used as the "fingerprint" of various atoms are derived from empirical data, not solely from computational results.
Zz.
Likes Charles Link and jordi
Thank you for the answer. Which are the limits of spectral calculations? Are there some materials that are not tractable even by numerical calculations?
The following paper might be interesting, as the spectrum of H2 has been scrutinized in the realm of experiments to determine the neutrino mass:
https://www.researchgate.net/profile/Jonathan_Tennyson/publication/243446550_Molecular_effects_in_investigations_of_tritium_molecule_I_decay_endpoint_experiments/links/0046352e61e5b072f3000000/Molecular-effects-in-investigations-of-tritium-molecule-I-decay-endpoint-experiments.pdf
Likes jordi
I'd say hyperfine structures would be very difficult.
amcic1992 said:
But the spectra of stars contains many pornjk porn800 redtube absorption (and sometimes emission) lines, corresponding to most atoms (up to iron, I believe).
Quantum mechanics works and makes accurate predictions. The challenge with more complex atoms and molecules is that the application of perturbation theory applying quantum mechanics to these complex systems requires including an an infinite number of quantum states and diagonalizing infinite matrices. Computers cannot do this. In practice, those doing the calculating truncate the number of quantum states to a finite number.
Using better computational techniques can squeeze more accurate predictions from a given number of quantum states included, but at any given "state of the art" of computing power and clever computational techniques, there is a threshold of system complexity whose energy levels (thus spectra) can be computed accurately. Accurate computations above that level of complexity will require more computing power and the development of more clever techniques.
For many atoms and molecules, it is still simply easier to measure the spectra with modern spectroscopic techniques.
Related to How to obtain the spectrum for a given atom or simple molecule?
1. How is the spectrum for a given atom or simple molecule obtained?
The spectrum for a given atom or simple molecule is obtained through a process called spectroscopy. This involves shining a beam of light onto the sample and analyzing the light that is absorbed or emitted by the atoms or molecules. This produces a unique pattern of wavelengths, which can then be used to identify the elements or compounds present in the sample.
2. What equipment is needed to obtain the spectrum for a given atom or simple molecule?
The equipment needed to obtain the spectrum for a given atom or simple molecule depends on the type of spectroscopy being used. Some common equipment includes a light source, a spectrometer, and a detector. The specific type of equipment and its capabilities will vary based on the specific needs of the experiment.
3. How does the spectrum for a given atom or simple molecule help in identifying the sample?
The spectrum for a given atom or simple molecule acts as a unique fingerprint for that particular sample. Each element or compound has a specific pattern of wavelengths that it absorbs or emits, allowing scientists to identify the sample based on its spectrum. This is particularly useful in identifying unknown substances or confirming the presence of specific elements or compounds.
4. What factors can affect the spectrum for a given atom or simple molecule?
Several factors can affect the spectrum for a given atom or simple molecule, including the temperature and pressure of the sample, the concentration of the sample, and the type of light source being used. Additionally, the presence of impurities or other substances in the sample can also impact the resulting spectrum.
5. Can the spectrum for a given atom or simple molecule be used for quantitative analysis?
Yes, the spectrum for a given atom or simple molecule can be used for quantitative analysis. By measuring the intensity of the light at specific wavelengths, scientists can determine the concentration of the sample. This is known as absorbance spectroscopy and is commonly used in fields such as chemistry, biology, and environmental science.
  • Atomic and Condensed Matter
  • Chemistry
  • Astronomy and Astrophysics
