High School How to pick some numbers out of 13 integers, by a 4 digits code
  • Thread starter Thread starter robertphy
    Arithmetic
The discussion revolves around deciphering a code made of up to four digits that corresponds to selecting numbers from the first 13 integers. Participants explore methods to connect the code to specific subsets of integers, noting that the sum of selected integers can match the last two digits of the code. Additionally, they consider using modular arithmetic to derive insights from the codes provided. A key suggestion involves using binary representation to map the four-digit codes to the subsets of integers. The conversation seeks further hints and strategies to advance the problem-solving process.
robertphy
TL;DR
This is the question I read in a Math quizzes book:
- you have the first 13 integers from 1 to 13
- someone gives you a code made of at most 4 digits (0 to 9)
- you decipher the code and tell him exactly which numbers he wanted from the list each number can be picked only once
For example.
case 1 He gives you 8191 and you tell he thought all the 13 integers from 1 to 13.
case 2 He gives you 6145 and you tell he thought only 1, 2, 13.
And so on.
I've not come up with any solutions yet. The only sparse ideas I have are:
case 1 if you sum the first 13 integers you get 91, so the last two digits of 8191
case 2 if you sum 1, 2, 13 you get the same result summing the digits of 6145
Also,
8191 mod 3 = 13
6145 mod 2 = 3
Beside that , I have no other clues how to move forward.
I would be grateful for some hints how to go on. Thank you very much.
Mathematics news on Phys.org
Hint: binary.
Likes pbuk, hmmm27, Gavran and 3 others
If might help to enumerate how many possible outputs there are. From a pure counting perspective, is it even possible to make a map from 4 digit codes to subsets of integers between 1 and 13?
Definite. Could fit 1/4 - 1/5 of the further ones required for a 14 element set, as well.
Hill said:
Hint: binary.
This is a very good hint: how are you getting on?
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
