Zaxo3000
- 10
We have a cylindrical tank of known dimensions. Attached at the bottom is a pipe perpendicular to the tank of known dimensions. We fill the tank with a liquid and let it drain out through the pipe. What formula will predict the volume of the tank at any time t? I believe the Hagen–Poiseuille equation (involves the viscosity of the liquid) and Pascal's law (involves the density of the liquid) are involved, but i cannot derive an equation for the volume at any time. All working and any explanation where ever necessary would be appreciated.
Heres my attempt at it:
ΔP = 8μLQ / πr^4
ΔP is the pressure drop
L is the length of pipe
μ is the dynamic viscosity
Q is the volumetric flow rate
r is the radius
ΔP = ρgΔh
g is acceleration due to gravity
ρ is the fluid density
Δh is the height of fluid
ΔP = 8μLQ / πr^4
ΔP = ρgΔh
Volume of tank = πr^2h
8μLQ / πr^4 = ρgΔh
Q = ρgΔh ✕ πr^4 / 8μL
This is essentially equal to Q = k Δh where k is = ρg ✕ πr^4 / 8μL
Im fairly sure is is redundant however as of course the rate of flow is proportional to the change in height of water as when the Δh is multiplied by the area of the circular face of the tank it will give the volume of the cylinder of water which has left through the pipe during the Δh. There has to be an equation for the relationship I am looking for as the results of the test will be consistent.
ΔP = 8μLQ / πr^4
r is the radius
ΔP = ρgΔh
ΔP = 8μLQ / πr^4
ΔP = ρgΔh
8μLQ / πr^4 = ρgΔh
