kuheli
- 14
if b is the mean proportion between a and c ,show that
abc(a+b+c)^3 = (ab+bc+ca)^3
[tex]\text{If }b\text{ is the mean proportion between }a\text{ and }c,[/tex]
[tex]\text{show that: }\:abc(a+b+c)^3 \:=\: (ab+bc+ca)^3[/tex]
[tex]\text{If }a,b,c,d \text{ are in continued proportion,}[/tex]
[tex]\text{prove that: }\;\frac{a}{d} \:=\:\frac{a^3 +b^3 +c^3}{b^3 + c^3 +d^3}[/tex]
soroban said:Hello again, kuheli!
I assume that continued proportion means geometric sequence.
So we have: .[tex]\begin{Bmatrix}a &=& a \\ b &=& ar \\ c &=& ar^2 \\ d &=& ar^3 \end{Bmatrix}[/tex] .where [tex]r[/tex] is the common ratio.
The left side is: .[tex]\frac{a}{d} \:=\:\frac{a}{ar^3} \:=\:\frac{1}{r^3}[/tex]
The right side is: .[tex]\frac{a^3+b^3 + c^3}{b^3+c^3+d^3} \:=\:\frac{a^3 + (ar)^3 + (ar^2)^3}{(ar)^3 + (ar^2)^3 + (ar^3)^3} [/tex]
. . . . [tex]=\;\frac{a^3 + a^3r^3 + a^3r^6}{a^3r^3+a^3r^6+a^3r^9} \;=\; \frac{a^3(1+r^3+r^6)}{a^3r^3(1+r^3+r^6)}[/tex]
. . . . [tex]=\;\frac{1}{r^3}[/tex]Q.E.D.
kuheli said:thanks a lot ...
The mean proportion problem is a mathematical problem that involves finding a number that is between two given numbers and has the same relationship to those numbers as they have to each other. This number is known as the mean proportion or the geometric mean.
The mean proportion is calculated by taking the square root of the product of the two given numbers. In other words, if the two numbers are A and B, the mean proportion is √(A x B). This number will be between A and B and will have the same ratio to A and B as they have to each other.
The mean proportion has many applications in mathematics and science. It is commonly used to find the missing term in a geometric sequence or to calculate the side lengths of similar shapes. It is also used in physics to calculate the average speed of an object over a given distance.
The mean proportion problem is closely related to the Pythagorean theorem. In fact, the Pythagorean theorem can be derived from the mean proportion problem. If we have a right triangle with sides A, B, and C, where C is the hypotenuse, then the mean proportion can be used to show that A² + B² = C².
Yes, there are many real-life examples of the mean proportion problem. For instance, if you have a rectangular garden with a length of 6 feet and a width of 8 feet, you can use the mean proportion to calculate the length of the diagonal. The mean proportion can also be used in photography to calculate the focal length of a lens or in finance to calculate compound interest.
