How to prove a simple graph is 2-connected?
  • Thread starter cxc001
  • Tags
    Graph
In summary, the problem states that for a simple graph G on n vertices with each vertex having a degree greater than or equal to n/2, deleting any vertex results in a connected graph. By using mathematical induction, we can prove that this statement holds true for all simple graphs with n vertices and deg(v) >= n/2.
cxc001
Problem: "Let G be a simple graph on n vertices such that deg(v)>= n/2 for every vertex v in G. Prove that deleting any vertex of G results in a connected graph."
Well, I tried to find the min. case.
Let k be the min. deg. of vertex in a simple graph,
n is number of vertices in G
so k = min{deg(v)} and k >= n/2,
I found the boundary for n is in [k+1, 2k] to satisfy the given inequality constraint.
n >=2 and k >=1
besides the very first case when k=1 and n=2, which is P2, a connected walk with two vertices and one edge,
the rest of the cases when n>=3 and k>=2 are exactly 2-connected graph
BUT HOW CAN I PROVE IT IS TO BE EXACTLY 2-CONNECTED GRAPH THOUGH?
If I can prove it is a 2-connected graph, then for any two vertices of G, there is a cycle containing both.
Then by deleting any vertex of a 2-connected graph would result in a connected graph. Since for any two edges of G, there is a cycle containing both.
I can either use the definition of 2-connected graph to prove it or maybe use induction to prove it at last.
Any suggestion would be really helpful!
Proof by induction:Base case:Let G be a simple graph with n=2 vertices and let deg(v) >= 1, then G is a connected graph.Induction hypothesis:Assume that for any simple graph G with n vertices such that deg(v) >= n/2, deleting any vertex of G results in a connected graph.Inductive Step:Let G be a simple graph with n+1 vertices such that deg(v) >= (n+1)/2, then deleting any vertex of G will result in a connected graph.Proof: Let v be the vertex in G that is to be deleted. Then there must be at least one edge incident to v, so that there are at least n/2 edges left in the graph. By removing v, the remaining n vertices form a graph G' with n vertices and each vertex in G' has degree greater than or equal to (n-1)/2. By the induction hypothesis, G' must be connected after deleting v, thus G is also connected after deleting v. Therefore, the statement holds true for G. Hence, by mathematical induction, we can conclude that deleting any vertex of a simple graph G on n vertices such that deg(v)>= n/2 for every vertex v in G results in a connected graph.
Related to How to prove a simple graph is 2-connected?
What is a simple graph and what does it mean to be 2-connected?
A simple graph is a mathematical structure consisting of a set of vertices and edges connecting these vertices. A graph is 2-connected if there are at least two distinct paths between any two vertices in the graph.
What is the significance of proving a simple graph is 2-connected?
Proving a simple graph is 2-connected is important because it ensures that the graph is connected enough to allow for efficient navigation between any two vertices. This is useful in many applications, such as network and transportation systems, where efficient connectivity is crucial.
How can I prove that a simple graph is 2-connected?
There are several methods for proving that a simple graph is 2-connected. One approach is to use the concept of cuts and bridges, where a cut is a set of edges whose removal would disconnect the graph, and a bridge is an edge whose removal would create two disconnected components. If a graph has no cuts or bridges, it is 2-connected.
Can a simple graph with a single vertex be 2-connected?
No, a simple graph with a single vertex is not considered 2-connected. In order for a graph to be 2-connected, it must have at least two distinct paths between any two vertices, which is not possible with only one vertex.
What are some real-world examples of 2-connected graphs?
Some real-world examples of 2-connected graphs include road networks, computer networks, and electric circuits. In these systems, it is important to have efficient and redundant paths between various points, making 2-connectivity a desirable property.
