How to Prove a2+b2 >= 2ab and x2+y2+z2 >= 1/3 c2?
In summary, the conversation discusses how to prove the inequality a2+b2 >= 2ab and then uses this to show that x2+y2+z2 >= 1/3c2 when x+y+z=c. The conversation also mentions using the "greater or equal to" sign and expanding the right-hand side of the inequality to prove the statement.
Michael_Light
113
Show that a2+b2 =>2ab, and hence, if x+y+z=c, show that x2+y2+z2 => 1/3 c2
How to prove this when we only have unknowns? The only thing i can think of for the first one is a (a+b)2= a2+b2 +2ab, but how to prove that a2+b2 =>2ab? For the second one i have no clue...
Often, we often write "greater or equal to" sign ([itex]\ge[/itex]) like this >=, to distinguish it from the "imply" sign ([itex]\Rightarrow[/itex]).
Well, you can think of (a + b)2, right? So what about (a - b)2? To solve the first part of this problem, you should also note that: the square of any real number is always non-negative.
Because c = x + y + z, and you are told to prove that:
[tex]x ^ 2 + y ^ 2 + z ^ 2 \ge \frac{1}{3} c ^ 2[/tex], or written in another rather different way, you are told to prove:
[tex]x ^ 2 + y ^ 2 + z ^ 2 \ge \frac{1}{3} \left( x + y + z \right) ^ 2[/tex]
Well, I would consider expand the RHS, and notice the fact that:
x2 + y2 >= 2xy (as proven in the first part)
Well, let's see if you can get this problem solved. If you get stuck again, just don't hesitate to ask. :)
FAQ: How to Prove a2+b2 >= 2ab and x2+y2+z2 >= 1/3 c2?
How do you prove a weird inequality?
To prove a weird inequality, you need to start by clearly stating the inequality and the variables involved. Then, you can use various mathematical techniques such as algebra, calculus, or geometry to manipulate the inequality until it simplifies to a known inequality or a statement that can be proved using known theorems or properties.
What are the common challenges when proving a weird inequality?
Some common challenges when proving a weird inequality include finding the appropriate starting point, choosing the right mathematical techniques to use, and ensuring that the proof is logically sound and rigorous. It can also be challenging to determine the most efficient and elegant way to prove the inequality.
Can a computer program be used to prove a weird inequality?
Yes, a computer program can be used to prove a weird inequality. This is known as computational proof, and it involves using mathematical software or programming languages to verify the inequality through numerical calculations or symbolic manipulation. However, the validity of the proof still depends on the accuracy of the program and the correct implementation of mathematical principles.
Are there any specific strategies for proving a weird inequality?
There are no specific strategies for proving a weird inequality, as each inequality may require a different approach. However, some general strategies that may be helpful include breaking the inequality into smaller parts, using counterexamples or special cases to disprove the inequality, and considering alternative ways to express the inequality.
How do you know if a weird inequality has been proven?
A weird inequality is considered proven if a logical and valid argument has been presented to support its truth. This can be through a formal mathematical proof, a computational proof, or a combination of both. The credibility of the proof also depends on the reputation and expertise of the person presenting it and the consensus of the scientific community.
