How to prove Kirchhoff's loop rule?
In summary, the conversation discusses the concept of proof in common test books, specifically in the context of simple one-loop systems with a battery and a resistor. It is mentioned that in these systems, the same current flows throughout the loop. However, in real-life situations, different currents may exist in different sections of the loop and electrons do not necessarily return to the same point. The idea that one point can only have one potential is also brought up, and the question of whether there is any proof for this concept is raised. The method of using induction to prove this idea is suggested, starting with one loop and extending it to multiple loops.
kelvin490
In common test books the "proof" is usually use an example of a simple one-loop system with battery and resistor. In such a case, the current actually goes round the loop and the same current flows throughout the loop.
However in actual case, there may be different currents in different sections of the loop, no electron actually returns to the same point.
Another way to use the idea that one point can only have one potential, but are there any proof for that? Why it is not possible to have electrons go through different path to have different energy when they pass through the same point?
It sounds like your understanding and confusion may be more fundamental, but you would prove it in general using induction. Prove it for one loop. Extend that to two loops, and then extend it to n loops...
Related to How to prove Kirchhoff's loop rule?
1. What is Kirchhoff's loop rule?
Kirchhoff's loop rule, also known as Kirchhoff's second law or Kirchhoff's voltage law, states that the algebraic sum of the voltages around a closed loop in a circuit must be equal to zero. This means that the total voltage supplied by a source must be equal to the voltage drops across all the elements in the loop.
2. Why is Kirchhoff's loop rule important?
Kirchhoff's loop rule is important because it helps to determine the currents and voltages in complex circuits. It is a fundamental law in circuit analysis and is used extensively in electrical engineering and physics.
3. How can Kirchhoff's loop rule be proved?
Kirchhoff's loop rule can be proved mathematically using the principles of conservation of energy and charge. It can also be proved experimentally by measuring the voltages and currents in a circuit and verifying that the rule holds true.
4. What are the assumptions made in Kirchhoff's loop rule?
The main assumption made in Kirchhoff's loop rule is that the circuit is in a steady state, meaning that the currents and voltages do not change over time. Additionally, the rule assumes that the circuit is a closed loop, and that all the elements in the loop are connected in series.
5. Are there any exceptions to Kirchhoff's loop rule?
In most cases, Kirchhoff's loop rule holds true. However, there are some exceptions, such as circuits with non-conservative electric fields or circuits with time-varying magnetic fields. In these cases, the rule may not be applicable, and other laws or principles must be used for analysis.
  • Other Physics Topics
