I How to prove that a scalar potential exists if the curl of the vector point function is zero?
  • I
  • Thread starter Thread starter immortalsameer13
    Vector calculus
A scalar potential exists if the curl of a vector point function is zero, as demonstrated by the closed curve integral being zero for any closed curve. This implies that the one-way integral between two points is path-independent, leading to a well-defined potential. By establishing a starting point, p_0, the integral values from this point to any other points can be calculated, confirming the existence of a scalar potential. The process relies on the properties of vector fields and their integrals over surfaces. Thus, the conditions for a scalar potential are satisfied when the curl of the vector field is zero.
immortalsameer13
scalar potential can be obtained by integrating the vector point function whose curl is zero but how to arrive at this result that a potential exist
Mathematics news on Phys.org
First show that if ##\mathrm{rot}\, v=0## then ##\int_Cv_xdx+v_ydy+v_zdz=0## for any closed curve ##C##. To do that
consider a 2-dimensional surface ##S## such that ##\partial S=C##
Likes FactChecker and topsquark
Because the closed curve integral is zero, the one-way integral from one point to another has only one answer no matter which path is taken. So the one-way integral gives you a well-defined definition of the potential.
ADDED: Establish a starting point, ##p_0##, for the beginning of a path to any and all other points. The integral values from ##p_0## to the other points gives a well-defined potential at those points.
Likes immortalsameer13
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
