How to Prove the Inequality of the Sequence T_n?
  • MHB
  • Thread starter Albert1
  • Tags
    Inequality
In summary, we can prove that $T_n=\left(1-\dfrac{1}{3^2} \right)\times \left(1-\dfrac{1}{5^2} \right)\times \left(1-\dfrac{1}{7^2} \right)\times \cdots\times \left[1-\dfrac{1}{(2n+1)^2} \right]$ satisfies $\sqrt{\dfrac {n+1}{2n+1}}<T_n < \sqrt{\dfrac {2n+3}{3n+3}}$ by using the expressions $P_n=\left(1-\dfrac{1}{2^2}
Albert1
1,221
$ T_n=\left(1-\dfrac{1}{3^2} \right)+\left(1-\dfrac{1}{5^2} \right)+\left(1-\dfrac{1}{7^2} \right)+\cdots+\left[1-\dfrac{1}{(2n+1)^2} \right]$
prove: $ \sqrt{\dfrac{n+1}{2n+1}}<T_n<\sqrt{\dfrac{2n+3}{3n+3}}$
Mathematics news on Phys.org
Could you please check the wording of this problem. The right-hand inequality is clearly false (each of the $n$ terms in the sum $T_n$ is close to $1$, yet their sum is supposed to be less than $\sqrt{(2n+3)/(3n+3)}$, which is less than $1$).
sory : a typo !
prove :
$ \sqrt{\dfrac {n+1}{2n+1}}<T_n < \sqrt{\dfrac {2n+3}{3n+3}}$
let $P_n=\left(1-\dfrac{1}{2^2} \right)\times \left(1-\dfrac{1}{4^2} \right)\times \left(1-\dfrac{1}{6^2} \right)\times \cdots\times \left[1-\dfrac{1}{(2n)^2} \right]$
let $Q_n=\left(1-\dfrac{1}{4^2} \right)\times \left(1-\dfrac{1}{6^2} \right)\times \left(1-\dfrac{1}{8^2} \right)\times \cdots\times \left[1-\dfrac{1}{(2n+2)^2} \right]$
$ T_nP_n=\dfrac{n+1}{2n+1},\,\,\, $$ T_nQ_n=\dfrac{2n+3}{3n+3}$
but $P_n<T_n<Q_n$
$\therefore \sqrt{\dfrac {n+1}{2n+1}}<T_n < \sqrt{\dfrac {2n+3}{3n+3}}$
Albert said:
prove :
but $P_n<T_n<Q_n$
View attachment 707 Easy, once you have seen it!
FAQ: How to Prove the Inequality of the Sequence T_n?
How do you prove the inequality of Tn?
The inequality of Tn can be proven using mathematical induction. This method involves proving that the statement is true for a specific value of n, and then showing that if it is true for any arbitrary value of k, it must also be true for k+1. This inductive step can be repeated until the statement is proven for all values of n.
What is the significance of proving the inequality of Tn?
Proving the inequality of Tn is important because it helps us understand the behavior and properties of the sequence Tn. It also allows us to make accurate predictions and calculations when using Tn in various mathematical contexts.
Can you give an example of how the inequality of Tn is used in real-life situations?
One example of how the inequality of Tn is used in real-life situations is in finance and economics. The sequence Tn can represent the value of an investment over time, and the inequality can help determine the minimum and maximum possible returns on the investment. This information can be useful for making financial decisions.
Are there any other methods for proving the inequality of Tn?
Yes, there are other methods for proving the inequality of Tn, such as using mathematical manipulations and properties of the sequence. However, mathematical induction is the most commonly used method as it provides a clear and systematic approach to proving the inequality for all values of n.
What are the limitations of the inequality of Tn?
The inequality of Tn is limited to the specific sequence Tn and may not apply to other sequences. Additionally, the inequality may only hold true for a certain range of values of n and may not be applicable for all values. It is important to carefully consider the assumptions and conditions when using the inequality of Tn in any mathematical context.
