How to prove this using Abel's summation formula?
  • Thread starter Thread starter Math100
    Formula Summation
To apply Abel's summation formula effectively, the choice of the function f(t) is crucial, and it can be any continuously differentiable function on the interval [x, y]. The discussion emphasizes the importance of selecting f(t) wisely, particularly in the context of Dirichlet's theorem on arithmetic progressions, which relates to the distribution of prime numbers. The participants explore how to derive the relevant sequences and the implications of setting parameters h and k in the theorem. They also discuss the mathematical intricacies involved in proving the theorem, including the definitions of a_n and the use of Dirichlet density. The conversation ultimately centers on the application of these concepts to enhance understanding of prime distributions and the effectiveness of the summation formula.
Math100
Prove that ## \sum_{\substack{prime p\leq x \\ p\equiv 3\pmod {10}}}\frac{1}{p}=\frac{1}{4}\log\log {x}+A+O(\frac{1}{\log {x}}) ##, for some constant ## A ##.
Suppose ## gcd(h, k)=1 ## for ## k>0 ##. Then, there exists a constant ## A ## such that for all ## x\geq 2 ##:
## \sum_{\substack{prime p\leq x \\ p\equiv h\pmod {k}}}\frac{1}{p}=\frac{1}{\varphi(k)}\log\log {x}+A+O(\frac{1}{\log {x}}) ##.
Abel's summation formula:
If ## A(x)=\int_{y}^{x}a(t)dt ##, then ## \int_{y}^{x}a(t)f(t)dt=A(x)f(x)-A(y)f(y)-\int_{y}^{x}A(t)f'(t)dt ##.
Before I apply/use the Abel's summation formula, how should I find ## f(x) ##?
Abel's summation formula goes
\sum_{x\leq n\leq y}a_n f(n)=A(y)f(y)-A(x)f(x)-\int_x^y A(t)f'(t)\,dt
with ##A(x)=\displaystyle{\sum_{0<n\leq x}}a_n## where ##(a_n)## is a sequence of real or complex numbers, and ##f(t)## any on ##[x,y]## continuously differentiable function. Your choice.
How do you reference the important equation under "relevant equations"?
https://en.wikipedia.org/wiki/Abel's_summation_formula
From the textbook and notes. But if ##f(t)## can be any on ##[x, y]##, then what would you choose? How to choose this ##f(t)## function wisely?
Dirichlet's theorem on arithmetic progressions says
\sum_{\stackrel{p\text{ prime }}{p\equiv h\pmod{k}\, , \,(h,k=1)}}\dfrac{1}{p}=\infty
Your theorem says
S(k,x):=\sum_{\stackrel{p\text{ prime }\leq x}{p\equiv h\pmod{k}\, , \,(h,k=1)}}\dfrac{1}{p}=\dfrac{1}{\varphi(k)}\log\log {x}+A+O\left(\dfrac{1}{\log {x}}\right)
so the boundary ##\leq x## changes everything.
Before we chose ##f(t)## let's look at the sequence, just to get an impression
\begin{matrix}
3& 13& 23& 43& 53& 73& 83& 103& 113& 163& 173& 193& 223& 233\\
263& 283& 293& 313& 353& 373& 383& 433& 443& 463&503& 523& 563& 593\\
613&643 &653& 673& 683& 733& 743& 773& 823& 853& 863& 883& 953& 983\\
1013& 1033& 1063& 1093& 1103& 1123& 1153& 1163& 1193& 1213& 1223& 1283& 1303& 1373\\
1423& 1433& 1453&1483& 1493& 1523& 1543& 1553&\ldots &&&&&&
\end{matrix}
The prime number theorem gives us ##\displaystyle{\lim_{x \to \infty}\dfrac{\pi(x)\log(x)}{x}=1}## where the prime-counting function is given as ##\displaystyle{\pi(x)=\sum_{\stackrel{p\text{ prime }}{p\leq x}}}.## The ##n-##th prime number can be approximated by ##p(n)\sim n\log(n).## The error approaches zero for growing ##n.##
We set ##h=3## and ##k=10.## This gives us from your theorem
S(10,x)= \dfrac{1}{4}\log\log {x}+A+O\left(\dfrac{1}{\log {x}}\right)
since ##\varphi (10)=|\{x\pmod{10}\,|\,(x,10)=1\}|=|\{1,3,7,9\}|=4.##
Do you want to prove the theorem?
Your theorem says
\begin{matrix}
\end{matrix}
Before I try to prove the theorem, I want to know, how did you get those numbers from ## 3 ## to ## 1553 ## from the sequence?
That was the easy part.
I copied the list up to ~1600 from https://de.wikibooks.org/wiki/Primzahlen:_Tabelle_der_Primzahlen_(2_-_100.000),
put it into an editor (textpad), changed the comma (,) globally to ampersand (&), dropped it in a begin-end-matrix environment here, deleted all numbers that did not end on 3, and finally inserted a newline command (\\) every fourteen primes.
If you want to prove the theorem, then why for ##(h,k)=(3,10)## and not generally for ##(h,k)##? And wasn't it proven in the book? You said it is from there.
I haven't found the exact version of Dirichlet's prime number theorem that your book lists but the one I did have found is heavy machinery and I seriously doubt that your version or the specification ##(h,k)=(3,10)## makes it a lot easier than that:
https://www.glk.uni-mainz.de/files/2018/08/Nickel.pdf (theorem 4.16, page 23/23)
The following proof below is from the book:
Let ## f(x)=\frac{1}{\log {x}} ## and ## a(n)=\frac{\log {n}}{n} ## if ## n\equiv h\pmod {k} ## is prime
and ## 0 ## otherwise.
By Dirichlet's Theorem, we have ## \sum_{n\leq x}a(n)=\frac{1}{\varphi(k)}\log {x}+R(x) ##,
where ## R(x)=O(1) ##.
Applying Abel's summation formula,
## \sum_{\substack{prime p\leq x \\ p\equiv h\pmod {k}}}\frac{1}{p}=\sum_{1<n\leq x}a(n)f(n) ##
## =\frac{1}{\log {x}}(\frac{1}{\varphi(k)}\log {x}+O(1))+\int_{2}^{x}\frac{1}{t\log^{2} {t}}(\frac{1}{\varphi(k)}\log {t}+R(t))dt ##
## =\frac{1}{\varphi(k)}+O(\frac{1}{\log {x}})+\frac{1}{\varphi(k)}\int_{2}^{x}\frac{dt}{t\log {t}}+\int_{2}^{\infty}\frac{R(t)}{t\log^{2} {t}}dt+\int_{x}^{\infty}\frac{R(t)}{t\log^{2} {t}}dt ##
## =\frac{1}{\varphi(k)}+O(\frac{1}{\log {x}})+\frac{\log\log {x}-\log\log {2}}{\varphi(k)}+C+O(\int_{x}^{\infty}\frac{dt}{t\log^{2} {t}}) ##
## =\frac{1}{\varphi(k)}\log\log {x}+A+O(\frac{1}{\log {x}}) ##.
But I don't understand the first part in this proof. Why letting ## f(x)=\frac{1}{\log {x}} ## and ## a(n)=\frac{\log {n}}{n} ##?
Yes, this was the difficult part that I thought you wanted to prove. It contains the so-called Dirichlet density ##\varphi (k)^{-1}## which isn't easy to see where it comes from.
Math100 said:
Applying Abel's summation formula, ## \sum_{\substack{prime p\leq x \\ p\equiv h\pmod {k}}}\frac{1}{p}=\sum_{1<n\leq x}a(n)f(n) ##
We want to apply Dirichlet's theorem in its classical form and improve the boundary of its estimation. The classical version reads (with ##a_n## as in your textbook)
\sum_{{p\ {\text{ prime }} \atop p\leq x} \atop p\equiv h{\pmod{k}}}{\frac{1}{p}}=
\sum_{0<n\leq x} a_n
={\frac{\log(x)}{\varphi (k)}}+R(x)
The problem is that we cannot really work with that sum on the left that contains so many gaps compared to all integers ##\{1,2,\ldots,[x]\}.## So we will start with a replacement
\sum _{{p\ {\text{ prime }} \atop p\leq x} \atop p\equiv h{\pmod {k}}}{\frac {1}{p}}=\sum_{n=1}^{[x]}b_n
We would like to set ##b_n=1/n## but we have to consider the gaps. Hence we define
b_n=\begin{cases}1/n&\text{ if }n\leq x \text{ is prime and }n\equiv h{\pmod {k}}\\0&\text{ else }\end{cases}
Our next difficulty is that we only have an estimation
\sum_{0<n\leq x}a_n=\sum _{{p\ {\text{ prime }} \atop p\leq x} \atop p\equiv h{\pmod{k}}}{\frac{\log p}{p}}
So we have ##b_p=\dfrac{1}{p}=\dfrac{a_p}{\log p}## which also holds for the zeros, so ##b_n=\dfrac{1}{n}=\dfrac{a_n}{\log n}## bridging the gaps. The difference is thus a factor ##f(n)=\frac{1}{\log n}## that we can use in Abel's summation formula since we can choose ##f(n)## as we like as long as it is continuously differentiable. All in all we have now - and note that ##a_1=0##
\begin{align*}
\sum_{{p\ {\text{ prime }} \atop p\leq x} \atop p\equiv h{\pmod{k}}}{\frac{1}{p}}&=
\sum_{n=1}^{[x]}b_n=\sum_{n=1}^{[x]}\dfrac{a_n}{\log n}=\sum_{n=1}^{[x]}a_nf(n)\\
&\stackrel{\text{Abel}}{=}\left(\sum_{n=1}^xa_n\right)f(x)-\left(\sum_{n=1}^1 a_n\right)f(1)-\int_1^x \left(\sum_{n=1}^t a_n\right)f'(t)\,dt \\
&\stackrel{\text{Dirichlet}}{=}\left({\frac{\log(x)}{\varphi (k)}}+R(x)\right)\cdot \dfrac{1}{\log x}-\int_2^x\left({\frac{\log(t)}{\varphi (k)}}+R(t)\right)\left(\dfrac{1}{\log t}\right)'\,dt\\
&= \dfrac{1}{\log x}\left({\frac{\log(x)}{\varphi (k)}}+O(1)\right)+\int_2^x \left(\dfrac{1}{t \log^2 t}\right) \left({\frac{\log(t)}{\varphi (k)}}+R(t)\right)\,dt\\
&\phantom{=}\ldots
\end{align*}
fresh_42 said:
Yes, this was the difficult part that I thought you wanted to prove. It contains the so-called Dirichlet density ##\varphi (k)^{-1}## which isn't easy to see where it comes from.We want to apply Dirichlet's theorem in its classical form and improve the boundary of its estimation. The classical version reads (with ##a_n## as in your textbook)
\begin{align*}
&\phantom{=}\ldots
\end{align*}
Just to confirm from where you left off,
\begin{align*}
&\frac{1}{\varphi(k)}+O(\frac{1}{\log {x}}+\int_{2}^{x}(\frac{1}{t\log {t}}\cdot \frac{1}{\varphi(k)}+\frac{R(t)}{t\log^2 {t}})dt\\
&=\frac{1}{\varphi(k)}+O(\frac{1}{\log {x}}+\frac{1}{\varphi(k)}\int_{2}^{x}\frac{dt}{t\log {t}}+\int_{2}^{x}\frac{R(t)}{t\log^2 {t}}dt+\int_{x}^{\infty}\frac{R(t)}{t\log^2 {t}}dt\\
&=\frac{1}{\varphi(k)}+O(\frac{1}{\log {x}}+\frac{\log\log {x}-\log\log {2}}{\varphi(k)}+C+O(\frac{1}{\log {2}})+O(\frac{1}{\log {x}})\\
&=\frac{1}{\varphi(k)}(1+\log\log {x}-\log\log {2})+C+O(\frac{1}{\log {x}})\\
&=\frac{1}{\varphi(k)}\log\log {x}+\frac{1}{\varphi(k)}(1-\log\log {2})+C+O(\frac{1}{\log {x}})\\
&=\frac{1}{\varphi(k)}\log\log {x}+A+O(\frac{1}{\log {x}})\\
\end{align*}
where ## A=\frac{1}{\varphi(k)}(1-\log\log {2})+C ##.
Is this correct?
\begin{align*}
\end{align*}
Is this correct?
Looks ok, modulo a few typos. Let me explain the calculation (explanations in brackets ##[\,\cdot\,]## at the end of a line):
\begin{align*}
&= \dfrac{1}{\varphi (k)}+O\left(\dfrac{1}{\log x}\right)+\ldots \quad \left[\dfrac{1}{\log x}\cdot O(1)=\dfrac{1}{\log x}\cdot C=\dfrac{C}{\log x}=O\left(\dfrac{1}{\log x}\right)\right]\\[12pt]
\ldots &+\dfrac{1}{\varphi (k)}\int_2^x \dfrac{1}{t \log t}\,dt+ C \int_2^x \dfrac{1}{t \log^2 t}\,dt \;\ldots\quad \left[R(t)=O(1)=C\right]\\[12pt]
&=\dfrac{1-\log\log 2}{\varphi (k)}+O\left(\dfrac{1}{\log x}\right)+\dfrac{\log\log x}{\varphi (k)}+\ldots \\[12pt]
&\quad\quad\quad\left[\dfrac{d}{dt}\log (\log (t))=\dfrac{1}{t\log t}\Rightarrow \int_2^x \dfrac{1}{t \log t}\,dt=\log (\log (x))-\log\log (2)\right]\\[12pt]
&\quad\quad\quad\left[\text{ and }\log\log 2 \text{ joins the first term}\right]\\[12pt]
\ldots &+ C\cdot \left(\underbrace{\int_2^\infty \dfrac{1}{t \log^2 t}\,dt}_{=\dfrac{1}{\log 2}}- \underbrace{\int_x^\infty \dfrac{1}{t \log^2 t}\,dt}_{=\dfrac{1}{\log x}}\right)\;\ldots\quad \left[\int_a^b =\int_a^\infty -\int_x^\infty \right]\\[12pt]
&=\dfrac{1-\log\log 2}{\varphi (k)}+O\left(\dfrac{1}{\log x}\right)+\dfrac{\log\log x}{\varphi (k)}+\underbrace{\dfrac{C}{\log 2}}_{=:A}-\dfrac{C}{\log x}\\[12pt]
&=\dfrac{\log\log x}{\varphi (k)}+A+O\left(\dfrac{1}{\log x}\right)+\dfrac{1-\log\log 2}{\varphi (k)}\;\ldots\quad\\[12pt]
&\quad\quad\quad\left[O\left(\log^{-1}(x)\right)-C\log^{-1}(x)=(C'-C)\log^{-1}(x)=O(\log^{-1}(x))\right]
\end{align*}
I hesitate to decide where to put ##\dfrac{1-\log\log 2}{\varphi (k)}## to.
If we pushed it in the first term ## \dfrac{\log\log x}{\varphi (k)}## we would get ##\gamma \dfrac{\log\log x}{\varphi (k)}=O\left(\dfrac{\log\log x}{\varphi (k)}\right)## which would ruin our nice first term, which is the entire reason we did this here.
We cannot put it into ##O\left(\dfrac{1}{\log x}\right)## because this gets small for increasing ##x## whereas ##\dfrac{1-\log\log 2}{\varphi (k)}## is independent of ##x##. It would ruin the boundary.
If we put it in ##A##, then we cheat a little bit. Why do we have ##\varphi (k)## explicitly in the first term if we treat it as a constant in ##A##? ##k## is a constant, so ##A## is probably a good place to be. Thus
A=\dfrac{C}{\log 2}+\dfrac{1-\log\log 2}{\varphi (k)}
##C## came in as ##R(t)=O(1)## which is already quite arbitrary. I guess that's why it's best that ##A## swallows ##\dfrac{1-\log\log 2}{\varphi (k)}## as another additive constant, est. ##+1.37\cdot \varphi (k).##
