How to prove this vector equation?
  • MHB
  • Thread starter Ganesh Ujwal
  • Tags
    Vector
In summary, we are trying to prove that $||\vec{a}+\vec{b}|| = ||\vec{a}-\vec{b}|| \iff \vec{a} \perp \vec{b}$ by using the fact that if the lengths of the two sides of a triangle are equal, then the triangle is isosceles. This hypothesis is equivalent to $\vec{a}\cdot \vec{b} = 0$, and we can proceed by squaring both sides and simplifying to reach this conclusion.
Ganesh Ujwal
56
Proving $||\vec{a}+\vec{b}|| = ||\vec{a}-\vec{b}|| \iff \vec{a} \perp \vec{b}$
Have some non-null $\vec{a}$ and $\vec{b}$.
I am trying to prove this to no avail:
$$||\vec{a}+\vec{b}|| = ||\vec{a}-\vec{b}|| \iff \vec{a} \perp \vec{b}$$
If we start with
$$||\vec{a}+\vec{b}|| = ||\vec{a}-\vec{b}|| \implies \vec{a} \perp \vec{b}$$
Our hypothesis is
$$||\vec{a}+\vec{b}|| = ||\vec{a}-\vec{b}||$$
Which tells us that both horizontal sides of this triangle have the same length, so we got an isosceles triangle. Not sure what to make out of that though.
Anyway, the hypothesis is equivalent to
$$\sqrt{(\vec{a} + \vec{b})\cdot (\vec{a} + \vec{b})} = \sqrt{(\vec{a} - \vec{b})\cdot (\vec{a} - \vec{b})}$$
From here, i don't know how to proceed?
Square both sides: $(\vec{a} + \vec{b})\cdot (\vec{a} + \vec{b}) = (\vec{a} - \vec{b})\cdot (\vec{a} - \vec{b})$. Now multiply out those brackets and simplify the resulting equation, to end up with $\vec{a}\cdot \vec{b} = 0$.
FAQ: How to prove this vector equation?
What is a vector equation?
A vector equation is an equation that expresses a relationship between two or more vectors. It is written in the form of v1 + v2 + ... + vn = u, where the vectors v1, v2, ..., vn are added together to equal the vector u.
How do I prove a vector equation?
To prove a vector equation, you need to show that both sides of the equation are equal. This can be done by performing operations on the vectors, such as addition, subtraction, or scalar multiplication, to transform one side of the equation into the other side. You can also use geometric properties of vectors, such as the angle between them or their lengths, to prove the equation.
What are the steps to prove a vector equation?
The steps to prove a vector equation are:
1. Write out the vector equation
2. Simplify each side of the equation using vector operations
3. Show that both sides are equal by performing the same operations on each side
4. If necessary, use geometric properties of vectors to further prove the equation
5. Write a conclusion stating that the vector equation has been proven
Can I use algebraic properties to prove a vector equation?
Yes, you can use algebraic properties, such as the distributive property or the associative property, to prove a vector equation. These properties can help you simplify the vectors and show that both sides of the equation are equal.
Are there any specific rules or formulas I should use to prove a vector equation?
There are no specific rules or formulas that must be used to prove a vector equation. It is important to have a strong understanding of vector operations and properties, and to be able to identify patterns and relationships between vectors. It may also be helpful to draw diagrams or use geometric concepts to assist in proving the equation.
