How to re-write this expression?
  • Thread starter kaffekjele
  • Tags
    Expression
In summary, the conversation is about simplifying an expression involving cosine expressions, but the suggestion to cancel n's in the expressions is incorrect and should not be attempted. The functions sin, cos, etc. should be thought of as functions and not be treated as numerical values that can be cancelled.
kaffekjele
Could someone please help me make this expression a little smaller? I'm sure there are things that cancels out or could be re written, but I generally suck at these things as I tend to break a few math rules along the way.
Could I for instance cancel n against n in the two last cosine expressions so I'm left with -cos∏-cos∏/2 at the end?
Expression is here: http://tinypic.com/r/2lw8047/6
Absolutely NOT! ##\cos(n \pi)/n## is most definitely not equal to ##\cos(\pi).## Just evaluate ##\cos(n \pi)/n## for ##n = 2, 3, 4## and see what you get.
Vital advice: put out of you mind forever any thought that you can cancel n's in such situations. Never try to cancel the n's in expressions like ##\cos(nx)/n, \; \sin(nx)/n, \: e^{nx}/n, \; \log(nx)/n, ## etc. You just cannot do it.
To add to what Ray said, you can give expressions for ##\cos (n\pi)## and ##\cos(\frac{n\pi} 2)## that don't involve cosines. Write them out for a few values of ##n## to see a pattern.
You must learn to think of sin, cos, etc. as functions.
If y(x) were defined as some function, I don't think you would say that
y(5n)/n was the same as y(5).
FAQ: How to re-write this expression?
How do I simplify this expression?
To simplify an expression, you can combine like terms and use the order of operations to evaluate the expression. Remember to work from left to right and use parentheses to group operations if necessary.
Can I change the order of operations when re-writing an expression?
Yes, you can change the order of operations when re-writing an expression as long as you follow the correct order. The order of operations is: parentheses, exponents, multiplication and division (from left to right), and addition and subtraction (from left to right).
What are some common mistakes to avoid when re-writing an expression?
Some common mistakes to avoid when re-writing an expression include forgetting to use parentheses to group operations, not following the correct order of operations, and missing any terms or factors when combining like terms.
How can I check if my re-written expression is equivalent to the original expression?
To check if your re-written expression is equivalent to the original expression, you can plug in values for the variables and evaluate both expressions. If they give the same result, then they are equivalent.
Can I add or subtract terms with different variables when re-writing an expression?
No, you cannot add or subtract terms with different variables when re-writing an expression. You can only combine like terms, which have the same variables and exponents.
