jjoll
- 20
P { margin-bottom: 0.08in; }
Hi,I am currently working on a project on “safety for transportation of crude oil”, I don't have technical background in chemical and material science that is why I need some expert opinions.1- is there and process, chemical or material that can be added to a oil (specially crude oil), or gasoline or petrol so that it neutralizes the flammability of that liquid or significantly lower it? It doesn't matter if it destroys that oil and makes it unusable.2- Any material that THICKENS the oil (make it more viscous and gel like), it would be great if it thickens the oil (turn it to gel) AND reduces flammability at the same time.
I have heard you can use water and detergent to gel the oil and make it less flammable. Is that true?3- I want the process to occur as fast as possible.Somebody told me:
“A detergent and water can be added to oils and fuels. That reduces flammability and thickens or gels the oil. (Mixing paraffin [kerosene] and liquid dish detergent creates a thick gel that looks & works like a Swarfega-type mechanics hand cleaner).Detergent molecules are polarised - one end binds to oils, the other to water. The chemical bond makes it harder for the oil to evaporate & it's the vapour that burns. “how long a process like this would take and is this true?
