How to report mass spectroscopy and elemental analysis in the RSC style
In summary: So it would be reported as m/z 181 (M+, 100%), 166 (M-15, 50%). In summary, the conversation discusses how to report elemental analysis and mass spectroscopy in the RSC style. For elemental analysis, the found values are substituted for x and y, while the theoretical percentage is represented by a and b. For mass spectroscopy, the % symbol is used to indicate relative intensity and assignments can be included in parentheses after the peak.
osc_wildly
Hi,
I am currently in the process of writing up my lab reports and wanted to know how to report mass spectroscopy and elemental analysis in the RSC style.
In my report guidelines it suggests elemental analysis should be reported as follows:
"Shown in the form: Found: C, 63.1; H, 5.4. C13H13NO4 requires C, 63.2; H, 5.3%."
My elemental analysis resulted in: Carbon:53.1%, Hydrogen 3.9%, Nitrogen 7.7% and Oxygen 35.3% and so the empirical formula is C8H7NO4
What I'm having trouble with is substituting my values for the values in the example, i.e.:
Found C, x; H, y. C8H7NO4 requires C, a; H, b%.
Any help on filing in the blanks would be greatly appreciated!
Also I wanted to know how to report mass spectroscopy in the RSC style, the example shows "m/z 183 (M+, 41%), 168 (38), 154 (9), 138 (31)."
But I want to know how to add assignments to the different factions. For example my mass spectrum has a peak at 181 (100) and another at 166 (50). I know that the difference is 15 so this corresponds to CH3, but how do I report this in the RSC style?
(Please don't just paste an excerpt from a journal; I would much prefer an explanation)
Thanks in advanced!
Chemistry news on Phys.org
For the elementary analysis, the x and y in your case are the found values, while the a and b refer to the theoretical percentage (based on the empirical formula).
For the mass spec analysis, the % refers to the relative intensity (relative abundance). The RSC guideline tells you to use the % symbol once.
Click here for the full guideline: http://www.rsc.org/images/GUIDELINES_tcm18-186308.pdf
I hope this helps.
Thank you so much for the reply!
I can now write up the elemental analysis thanks to you!
I'm still confused on how to report assignments to mass spectroscopy. For example my mass spectrum has a peak at 181 (100) and another at 166 (50). I know that the difference is 15 so this corresponds to CH3. If someone could show me how to report this by including the CH3 assignment to the peak difference I would be extremely grateful!
Thanks again, and I look forward to hearing from you!
I think you just state that the 166 peak is an M-15 peak in parenthesis.
Dear writer,
Thank you for your inquiry regarding reporting mass spectroscopy and elemental analysis in the RSC style. I am happy to assist you with this matter.
For reporting elemental analysis in the RSC style, it is important to follow the format provided in your report guidelines. In the example provided, the values for carbon and hydrogen are given as percentages. To fill in the blanks for your own analysis, you will need to convert your values from percentages to the same format used in the example. This can be done by multiplying your percentages by 100. For example, your carbon value of 53.1% would become 53.1 x 100 = 53.1%. Once you have converted all of your values, you can then substitute them into the formula provided in the example.
As for reporting mass spectroscopy in the RSC style, it is important to include the m/z (mass-to-charge ratio) values and their corresponding intensities. In the example provided, the m/z values are listed in parentheses after the assigned peak. To add assignments to your own spectrum, you can use the same format by listing the m/z values and their corresponding intensities, and then adding the assignment in parentheses after the value. For example, you could report your peaks as: m/z 181 (100, CH3) and 166 (50, C2H5).
I hope this explanation helps you with reporting your mass spectroscopy and elemental analysis in the RSC style. If you have any further questions, please do not hesitate to ask. Good luck with your lab reports!
Best regards,
FAQ: How to report mass spectroscopy and elemental analysis in the RSC style
1. How do I format my mass spectroscopy data in the RSC style?
In the RSC style, mass spectroscopy data should be reported in the following format: [M]+ (m/z) [relative intensity (%)] where M represents the parent ion and m/z is the mass-to-charge ratio. The relative intensity should be reported as a percentage and should be aligned to the decimal point. For example, [M]+ (m/z) [100.00%].
2. What information should be included in a mass spectrum figure in the RSC style?
A mass spectrum figure in the RSC style should include the molecular formula, chemical structure, and any relevant peaks or fragments with their corresponding m/z values and relative intensities. The figure should also have a clear and concise title and should be appropriately labeled with axis titles and units.
3. How should I report elemental analysis data in the RSC style?
Elemental analysis data should be reported in the following format: [element] [percentage of element present]. The percentages should be aligned to the decimal point and add up to 100%. The elemental analysis data should also include the method used for analysis and any relevant conditions, such as temperature and pressure.
4. Do I need to include a table of elemental analysis data in my report?
It is not necessary to include a table of elemental analysis data in your report, but it is recommended to provide a summary of the data, either in the text or in a figure. This summary should include the molecular formula and the percentages of each element present. If a table is included, it should follow the RSC style guidelines for table formatting.
5. How do I cite mass spectroscopy and elemental analysis data in the RSC style?
To cite mass spectroscopy and elemental analysis data in the RSC style, you should use the standard citation format for the type of source being used. For example, if you are citing a journal article, you would use the author-date citation style with superscript numbers for in-text citations. If you are citing a book, you would use the author-title citation style. Consult the RSC style guide for more specific citation guidelines.
