How to scale a velocity profile
In summary, the conversation discusses scaling of velocity profiles for comparison and the difficulty in computing the differences between the profiles due to different time durations. The proposed solution involves scaling the time component of the profiles to the same duration using a linear interpolation method. However, this results in different time values for each profile, making it difficult to compute the difference between corresponding velocity points. Possible solutions include smoothing the profiles or representing them as piecewise continuous functions to evaluate the difference and compute the RMS velocity difference.
bradyj7
122
Hello,
I am reading a paper in which the author describes how he scales the velocity profile of a car.
He is doing this so that he can compare the velocity profiles of cars.
This is an extract from the text:
The first methodology consisted of evaluating the similarities between velocity profiles by computing the differences between their velocity profiles. This is a direct method, since the velocity profiles are considered in their entirety. The aim was not to quantify the links between different velocity profiles, but simply to highlight the similarities that might be present. To apply this methodology, it was first necessary to scale the velocity profiles and to perform a linear interpolation (step of 0.1 s) since all velocity profiles do not all have the same duration and the same time resolution. This was achieved by using the ECE part of the NEDC cycle as a reference. Consequently, once scaled, all the cycles had the same duration of 195 s. A comparison of the original and scaled NEDC cycles is illustrated in Figure 1.
https://dl.dropbox.com/u/54057365/All/scaleNEDC.JPG
My question is, if I had the time and velocity values of the "original NEDC" velocity profile, how would you actually scale it to achieve the "scaled NEDC". How would you scale the numbers to fit in the 195 second time frame?
Thank you
Here is the data in an excel sheet:https://dl.dropbox.com/u/54057365/All/NEDC.xlsx
bradyj7 said:
Hello,
Thank you
From the figure, it looks like the only parameter that has been scaled is the time. If t is the running time in the experiment, and tmax is the overall maximum time, then the scaled time is t x 195/ tmax
Thanks very much
Hello ChesterMiller,
You helped me scale the time parameter of velocity profiles above for a vehicle a number of weeks ago. Thank you.
I was wondering if you had the time to help me with something else?
When I scale the velocity profiles in excel the resulting times are same length (in seconds) but they occupy a different number of cells (in length).
I am trying to apply this methodology to them to compute the difference between the profiles. But because they occupy a different number of cells I cannot apply it because the "t" values are different lengths.
https://dl.dropbox.com/u/54057365/All/QD.JPG
I have attached a workbook here with two example original and scaled profiles
https://dl.dropbox.com/u/54057365/All/QD.xlsx
I would be grateful if you had the time to consider it.
Kind Regards
J
It all depends on what you are trying to do, and what the data represents. It looks like you are trying to determine the rms velocity difference between the two velocity variations.
Do you want to smooth the differences between the two profiles first, or do you to include all the sturucture? If you want each of the profiles smoothed first, you can fit a Fourier series to the variation and include only the first few terms. Or fit another type of smooth curve.
If you want to include the sturucture, you can join all the sequential pairs points on each curve by straight lines, and interpolate between the points. Or you can represent each of the functions as a series of steps (like a bar chart), with constant values from half way between one pair of points, to half way between the next pair of points. In any event, you are fitting each of the velocity variations as a piecewise continuous function of time. Then you can evaluate the difference between the curves at any value of the time. Then you can integrate.
[tex]RMS = \frac{1}{t_{max}}\int_0^{t_{max}}(v_2(t)-v_1(t))^2dt[/tex]
This equation is the continuous form of your discrete summation relationship.
Hello,
Thank you for your reply. I do not need to smooth the velocity profiles.
Yes, I am trying to compute rms velocity difference between the two velocity variations.
My problem is that velocity profiles have different time duration. Hence, I have scaled them to same duration.
My problem is that now that they are scaled, the time values are not the same so I cannot compute the difference between to corresponding velocity points.
For example, say profile A is 970 seconds and Profile B is 1075 seconds. So I scaled the time component of both profiles using your method above to 177 seconds.
t x 177/ tmax (970)
t x 177/ tmax (1075)
https://dl.dropbox.com/u/54057365/All/scale.JPG
This is an example of the time values after scaling.
https://dl.dropbox.com/u/54057365/All/values.JPG
Because the scaled time values are not the same, i cannot subtract the corresponding velocities.
I have been struggling with this for a few days but cannot seem to figure it out.
I'd appreciate any help you could offer.
Regards
OK. Then just follow the advise I gave you in my previous posting. Fill in the regions between the grid points with straight lines or stepwise variations, and then integrate numerically. Use small time increments in the integration. If the times at the grid points on the scaled profiles had actually matched, doing this integration would have given you the exact same result as you summation equation.
Related to How to scale a velocity profile
What is a velocity profile?
A velocity profile is a graphical representation of the velocity distribution of a fluid, gas, or other substance as it flows through a particular area or system. It shows how the velocity changes with position and is an important tool for understanding and analyzing fluid flow.
Why is it important to scale a velocity profile?
Scaling a velocity profile is important because it allows us to compare and analyze data from different systems or experiments. By scaling, we can remove the influence of factors such as flow rate or pipe diameter and focus on the underlying patterns and trends in the velocity distribution.
What are the different methods for scaling a velocity profile?
There are several methods for scaling a velocity profile, including normalization, dimensional analysis, and empirical correlations. Normalization involves dividing each velocity value by the maximum velocity, while dimensional analysis involves using mathematical equations to relate different variables in the system. Empirical correlations are based on experimental data and can provide more accurate results.
How can scaling a velocity profile help with design and optimization?
Scaling a velocity profile can provide valuable insights for the design and optimization of systems that involve fluid flow. By understanding the underlying patterns and relationships in the velocity distribution, engineers and scientists can make informed decisions about the design and operation of systems to improve efficiency, reduce costs, and minimize potential issues.
What are some common challenges when scaling a velocity profile?
One of the main challenges when scaling a velocity profile is selecting the appropriate scaling method for the specific system or experiment. Additionally, data collection and accuracy can also be challenging, as small errors or variations in measurements can greatly affect the resulting scaled profile. It is important to carefully consider all factors and uncertainties when scaling a velocity profile.
  • Mechanical Engineering
15K
11K
