- #36
- 24,492
- 15,023
Interesting! Do you have a reference for this? I thought to define the standard topology on ##\mathbb{R}^n## you need a proper metric. A pseudo-metric won't do I think.
vanhees71 said:I thought to define the standard topology on ##\mathbb{R}^4## you need a proper metric.
PeterDonis said:What I said is that the smooth structure has to be compatible with having a locally Minkowski pseudo-metric.
I take that like this:Infrared said:Take ##X=Y## to be your favorite smooth manifold, and ##f:X\to X## a homeomorphism that is not smooth. Then the pullback of the smooth structure on ##X## by ##f## gives you a new smooth structure.
Or for example, if you fix a homeomorphism of a square with a circle, this gives you a smooth structure on the square, etc.
cianfa72 said:Endow then the square with a smooth structure -- basically define an atlas for it -- and define an homeomorphism *not* smooth with the circle (endowed as said before with the smooth structure as submanifold of ## \mathbb R^2##).
The following two charts should define a smooth atlas for the square (note the two regions of overlap are open)Infrared said:The business of finding a homeomorphism that isn't smooth in the first paragraph was meant to find two distinct smooth structures on X. If this is what you want to do for X=Square, then the above is right, but you should explain how you are picking a smooth structure on the square in the first place.
Aren't coordinate singularities a thing? Wouldn't that be an example of what the OP is talking about? Functions that are "sharp" at a point in one coordinate system but not another?PeterDonis said:He doesn't give any specific examples and I have never encountered any, or encountered any such statement in any GR text.
Any comment, is that correct ?cianfa72 said:The following two charts should define a smooth atlas for the square (note the two regions of overlap are open)
Anyway I believe it is not the 'restriction' of the ##\mathbb R^2## smooth structure just because the square is not a submanifold of ##\mathbb R^2##
I believe he just mean a 'not smooth sphere' with let me say a sort of 'corner' in some partDragon27 said:What is this sphere with a little edge? Isn't it a different object altogether?
He wasn't being careful. He probably meant that the two are the same topological space with two different smooth structures. But in dimension 2 the to different structures are diffeomorphic.cianfa72 said:Actually I've another doubt about what he said at this minute . It seems that the sphere in ##\mathbb R^3## and the sphere where I make a 'little edge' (basically folded a little) are no longer diffeomorphic
My concern is that he said in dimension 2 there exist basically just one smooth structure - up to diffeomorphism -- so why then a such diffeomorphism does not exist between them ?
Well, I'm not sure what he meant exactly. I know (as is explained and the end of that lecture) that a topological manifold in dimension less than 4 has a unique differential structure. So I would suppose that two smooth manifolds that are homeomorphic should be automatically diffeomorphic (for ##n<4##)? And what he meant is that a sphere with an edge isn't diffeomorphic to the regular sphere because it's not smooth in the first place?cianfa72 said:I believe he just mean a 'not smooth sphere' with let me say a sort of 'corner' in some part
In dimensions 1, 2, 3, any pair of homeomorphic smooth manifolds are diffeomorphic.
Watching it again, I believe as follows:martinbn said:He wasn't being careful. He probably meant that the two are the same topological space with two different smooth structures. But in dimension 2 the to different structures are diffeomorphic.
