How to separate CO2 into C and O2
  • Thread starter Jacquesl
  • Tags
    Co2
In summary: Carbon dioxide is not released because it isn't in a form that would be beneficial. The carbon is not in elemental form and the oxygen is bound to lithium.In summary, separating CO2 into C and O2 can be done by heating it, feeding it to a plant, or using a catalyst of iron doped zeolite and hydrogen. However, these methods require a lot of energy and are not very efficient. NASA is currently researching ways to convert CO2 into oxygen, but it is a difficult and costly process. Other methods, such as using activated charcoal or a strong base, also exist but do not release oxygen as a byproduct.
  • #36
DrStupid said:
And because CO is only half the way to carbon I suggested a second step to complete the separation of CO2 into C and O2.
Doh! You're right. That would address the OP's original question.
<h2> How is CO2 separated into C and O2?</h2><p>The most common method for separating CO2 into C and O2 is through a process called electrolysis. This involves passing an electric current through a solution of CO2, which causes the CO2 molecules to break apart into carbon and oxygen atoms.</p><h2> What equipment is needed for separating CO2 into C and O2?</h2><p>The equipment needed for separating CO2 into C and O2 includes a power source, electrodes, and a container for the CO2 solution. The electrodes can be made of various materials, such as platinum or graphite, and the container can be made of glass or other non-reactive materials.</p><h2> Can CO2 be separated into C and O2 without using electricity?</h2><p>Yes, there are other methods for separating CO2 into C and O2, such as using chemical reactions or high temperatures. However, these methods may be more complex and less efficient compared to electrolysis.</p><h2> What is the purpose of separating CO2 into C and O2?</h2><p>The main purpose of separating CO2 into C and O2 is to obtain pure carbon and oxygen, which can then be used for various industrial processes. Additionally, this process can also help reduce the amount of CO2 in the atmosphere, which is a major contributor to climate change.</p><h2> Are there any environmental concerns with separating CO2 into C and O2?</h2><p>While separating CO2 into C and O2 can have environmental benefits by reducing atmospheric CO2 levels, the process itself can also have negative impacts. The electricity used in electrolysis may come from non-renewable sources, and the byproducts of the process, such as hydrogen gas, can also contribute to air pollution. Therefore, it is important to consider the overall environmental impact of the process before implementing it on a large scale.</p>
FAQ: How to separate CO2 into C and O2
