How to show an isomorphism between groups?
In summary, the most common way to show an isomorphism between groups is to use theorems about the structure theory of groups. This can help you deduce the properties that the isomorphism map must satisfy, without necessarily having to define the map explicitly.
blahblah8724
32
Is the only way to show an isomorphism between groups is to just define a map which has the isomorphism properties?
So for example for a group [itex] G [/itex] with order 15 to show that [itex] G \cong C_3 \times C_5 [/itex] would I just have to define all the possible transformations to define the isomorphism?
Thanks!
In a sense, yes, but you don't have to define the map explicitly. You can use theorems about the structure theory of groups to help you out. These are theorems that say something along the lines of "if a group satisfies property P, then it must also satisfy property Q". So, for instance, a group of order 15 must have subgroups H and K of orders 3 and 5 (by Cauchy's theorem), and these subgroups must be normal (by Sylow's theorem), and their intersection must be trivial (by Lagrange's theorem), so G must be isomorphic to the internal direct product HxK (this follows from another structure theorem - which one?).
Of course, after making all these deductions, you can explicitly write down an isomorphism [itex]G \to C_3 \times C_5[/itex], but the point is you didn't have to start out by looking for such a map.
Related to How to show an isomorphism between groups?
1. How do you define an isomorphism between groups?
An isomorphism between two groups is a function that maps the elements of one group to the elements of another group in a way that preserves the group structure. This means that the function must be bijective, meaning each element in one group has a unique corresponding element in the other group, and it must also preserve the group operation, meaning the result of combining two elements in one group must be the same as combining their corresponding elements in the other group.
2. What is the importance of showing an isomorphism between groups?
Showing an isomorphism between groups can help us understand the relationship between different groups and their structures. It also allows us to transfer knowledge and techniques from one group to another, making problem-solving and analysis easier.
3. How can you prove that two groups are isomorphic?
To prove that two groups are isomorphic, you must first define a function between them and then show that it is bijective and preserves the group operation. This can be done by showing that the function is both injective (one-to-one) and surjective (onto) and that it satisfies the group operation property.
4. Are all groups isomorphic to each other?
No, not all groups are isomorphic to each other. Groups have different structures and properties, and an isomorphism can only exist between groups with the same structure. For example, an isomorphism cannot exist between groups with different orders or different group operations.
5. Can an isomorphism only exist between groups with the same elements?
No, an isomorphism can exist between groups with different elements as long as the group structures are the same. For example, the group of even integers under addition and the group of real numbers under multiplication are isomorphic, even though their elements are different.
  • Linear and Abstract Algebra
